musselmark
Today I tried to start my TN-75 and it wouldn't start, would just turn over so I bled it and finally got it to start . It would rev up normally for a couple of seconds and then die down to around 1000 rpm. It will idle fine but when I give it more throttle it makes more smoke but will not rev up. I checked the hose from tank for obstructions, nothing. I replaced the fuel lift pump with a new one and no improvement. It is cold here in eastern canada so I dumped 1/2 gallon of methyl hydrate and injector cleaner in with no improvement. Let it idle for 1/2 hour and no improvement. If I shut it off and bleed it at the filter and then start it up it will rev up again for a couple of seconds and then the same thing. Feels like it is starving for fuel but why would it smoke, you would think it would be running lean. Thanks for any help
