2005 MF 1533
/ 2005 MF 1533
Seller said we could buy his tandem axle trailer for $6-700
has the implements loaded on it for us to use to take to the property and also said we could use it to move the tractor as well even if we didn't buy it from him. I'm thinking if it looks decent, we'll get it.
/ 2005 MF 1533
Well, we bought it for $600
He also gave us some forks he had made that would fit on bucket. Open the clamshell a bit and sit it on them then close the bucket. Not sure what we will ever do with them, but I'm sure something will come along needing to be lifted.
here's the trailer. 16' long...needs a bit of tack welding done and will get that done at the shop here at work.
The Allis Chalmers in the background is the bossman's, not ours. :(
/ 2005 MF 1533 #13
you got a fair deal on the trailer ,2006 i got a 16 ft hd trailer with pintel hitch . 1st thing i did was pulled the wheels off , inspected the drums , brakes shoes ,n bearings. got new tires ,repainted n rewired trailer . installed new lights ,decking ,n got a battery back up break away system.installed a brake controller in the truck cab 2005 chevy 2500 HD .
/ 2005 MF 1533
We didn't get the trailer. Just took it back today (seller let us use it and check it out before buying). Had sides welded up (simple job), but needed new shackles, bearings and possibly springs.
Borrowing a trailer for now, and actually supposed to pick tractor up from dealership in an hour or two.
Question, though...
any idea on what the tractor weighs with FEL? (ours is 4 in 1, so it would be a little heavier than normal 1525 FEL, I assume)
/ 2005 MF 1533
thanks
got about an hour on it today
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
2025 MMS MS36C (A60463)
2025 MMS MS36C...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
2016 Lawnhorn Utility Trailer (A60352)
2016 Lawnhorn...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
