2005 Kubota L3130 : Manual trans with 4x4 : Small metal flakes in front axle fluid
   / 2005 Kubota L3130 : Manual trans with 4x4 : Small metal flakes in front axle fluid #1
hendr1x
2003 Kubota L3130
Hello everyone,
I just bought this tractor. It is completely new to me. It had a leaking seal so first thing I did was pulled off the front knuckles. When draining the fluid it had a fair amount of flakes in it. All were every small. I just wanted to get some advise on how to handle this. Should I change all the bearings or should I inspect and only change the ones that I can see/feel damage on? For the gears, if they visually look fine can I assume they are fine? There seems to be a some bearings up in the tube, its got a front diff (which I haven't look at yet), should I tear all that down that as well?
I would appreciate any help I can get for this job.
-Justin
   / 2005 Kubota L3130 : Manual trans with 4x4 : Small metal flakes in front axle fluid #2
How many hours on the tractor? I would expect to see small flakes if it's the original gear oil. Probably would have looked the same if you changed the fluid right when new. I'd only be worried if there were chunks or broken pieces.
   / 2005 Kubota L3130 : Manual trans with 4x4 : Small metal flakes in front axle fluid #3
Small flakes like this?...LOL
   / 2005 Kubota L3130 : Manual trans with 4x4 : Small metal flakes in front axle fluid #4
Hello everyone,
-Justin
Welcome to TBN, Justin.
For future queries- The relevent statistic is the 'hours' as S219 says, below.
I agree, that flakes aren't unusual - But worth keeping an eye on.
Change the oil across the front axle in all compartments. Check levels regularly and change again when you change engine oil and monitor the 'flakeage'.
Keep an ear open for adverse noises.
At this stage I'd go with the old adage - If it ain't broke - Don't fix it.
Thanks for responses guys. So no chunks...definitely not like the pictures, but basically glitter size...a fair amount of it. I might strain the oil pan to get a better idea of quantity. The tractor has 2k hours. The fluid isn't old because its been leaking. I don't know how much exactly but both tires had a fair amount of coating on them..strangely the side that had the most, had less flakes.
The gears in the front diff look good from what I can see.
   / 2005 Kubota L3130 : Manual trans with 4x4 : Small metal flakes in front axle fluid #6
Sounds fairly normal. Small particles are typical. You start seeing BIG particles you should worry...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
1991 Peterbilt 378 T/A Dump Truck (A50323)
1991 Peterbilt 378...
John Deere 2210 Compact Tractor (RUNS) (A50774)
John Deere 2210...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
