Rotary Cutter 2005 JD HX14
/ 2005 JD HX14 #1
Weekend Farmer
I am looking at buying a 2005 JD HX14 Rotary Cutter for clipping CRP ground. There are a lot of saplings (some as big as 3"). Does anyone know if this is a good fit for the application? Are these good cutters?
/ 2005 JD HX14 #2
I have an HX15 batwing and HX10. Both pull types. Both about 5 years old. Bought both used but in very good condition. Have not had any issues but only use them about 50 hours/year each. The HX14 will need for fairly flat gound due to its design and could be prone to scalping. I like the domed, double deck. Makes most dents underneath not visible and water/grass tends to fall off the deck.
I do cut some cedar trees with them. Some as big as 4", but go over them very slowly. They will slash through 2" brush with no issues.
/ 2005 JD HX14
Thanks for the info. This cutter that I am thinking about buying is in like new condition and I will only use it less than 50 hrs a year.
2015 Chevrolet 15 Passenger Express Van (A62613)
2015 Chevrolet 15...
2022 EZ-GO ELITE...
2023 JCB 270T SKID STEER (A65053)
2023 JCB 270T SKID...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
Lowe Quick Attach 1650 Classic Hydraulic Auger Drill & Bit (A66285)
Lowe Quick Attach...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
