Rotary Cutter 2005 JD HX14
/ 2005 JD HX14 #1
Weekend Farmer
I am looking at buying a 2005 JD HX14 Rotary Cutter for clipping CRP ground. There are a lot of saplings (some as big as 3"). Does anyone know if this is a good fit for the application? Are these good cutters?
/ 2005 JD HX14 #2
I have an HX15 batwing and HX10. Both pull types. Both about 5 years old. Bought both used but in very good condition. Have not had any issues but only use them about 50 hours/year each. The HX14 will need for fairly flat gound due to its design and could be prone to scalping. I like the domed, double deck. Makes most dents underneath not visible and water/grass tends to fall off the deck.
I do cut some cedar trees with them. Some as big as 4", but go over them very slowly. They will slash through 2" brush with no issues.
/ 2005 JD HX14
Thanks for the info. This cutter that I am thinking about buying is in like new condition and I will only use it less than 50 hrs a year.
Skeleton Backing Plate (A62679)
Skeleton Backing...
2012 Ford F350 Truck (A62679)
2012 Ford F350...
CHANDLER 10' STAINLESS STEEL FERTILIZER SPREADER (A64277)
CHANDLER 10'...
White Oak Slabs (A65640)
White Oak Slabs...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
28 Gauge R Panels (A65640)
28 Gauge R Panels...
