3-Point Hitch 2005 BX23D with Everything Attachments Posthole digger
   / 2005 BX23D with Everything Attachments Posthole digger #1
mendodave
Little River, CA
Kubota BX23
Well, I am one sore puppy...
I bought my BX23 used, and it did not come with the 3pt hitch components.
my local Kubota dealer said that the BX2506 3pt hitch kit for the BX25 would fit, but with extra parts left over, and they were right.
Getting the backhoe off was pretty straight forward, read the manual first! Getting to be an old fart has its benefits! :laughing:
that took a half hour. the hitch components took about twice that, mostly because I took them off again to try reversing the components to see if the fit was better, and then back again.
the posthole digger was another hour or more, doing all this alone was not too bad, but I was very sore the next day, and still am. That thing digs a hole likkity-split! I buried the thing, 9"x4', baddaBOOM...and the engine stalled.
all is well, and 5 holes dug, plants planted, laundry line hung up, and french drain ready to fill with gravel.
I thought maybe other BX23 owners might like to know about that BX2506 kit, $216.
Mendo
   / 2005 BX23D with Everything Attachments Posthole digger #2
Welcome to the forum and thanks for the info . .
   / 2005 BX23D with Everything Attachments Posthole digger #3
Welcome to the Forum.
   / 2005 BX23D with Everything Attachments Posthole digger #4
Getting the backhoe off was pretty straight forward, read the manual first! Getting to be an old fart has its benefits! :laughing: that took a half hour. the hitch components took about twice that, mostly because I took them off again to try reversing the components to see if the fit was better, and then back again.
It will definitely get easier removing and installing the backhoe with a little bit of practice. Once you've done it a few times you should be able to accomplish it in 5 or 10 minutes. Removing and installing the 3 ph assembly is more physical work but I can usually get it done in about 10 minutes.
You probably already know this but you should avoid loading a Diesel engine to the point of stalling it if possible. Sounds like you got a lot accomplished with your BX 23 already. They are great tractors for a home owner.
Sent from my iPad using TractorByNet
   / 2005 BX23D with Everything Attachments Posthole digger #5
I know this doesn't help you, but back in the day, the BX-23 and BX-24 were sold with a 3-pt hitch kits. My first Kubota was a used BX-23 and the dealer threw in the kit.
Here's a pic of the 23.
   / 2005 BX23D with Everything Attachments Posthole digger #6
nice! so what parts were left over from 3 pt install?
   / 2005 BX23D with Everything Attachments Posthole digger #7
Congrats on your bx buy, as a used bx owner I know how pleased you must be : )
I was curious about this "bx2506 kit". Is this some adaptor for the bx that lets' you use 3PH attachments intended to be used on the bx25?
thanks
Hi
the BX2506 IS the 3pt hitch. Apparently the newer models no longer come with the 3pt hitch included.
This is what you need to connect any 3pt attachments. I will take photos of the extra bits this weekend.
   / 2005 BX23D with Everything Attachments Posthole digger #9
oh, well thanks for that info, I did not realize bx23 models shipped with out 3PH's. What year is it?
3ft 5-Point Metal Star (A55853)
3ft 5-Point Metal...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
Native American Wooden Head Statue (A55853)
Native American...
2023 CATERPILLAR 259D3 SKID STEER (A52707)
2023 CATERPILLAR...
