2004 John Deere Gator HPX release latch for dump bed is stuck
   / 2004 John Deere Gator HPX release latch for dump bed is stuck #1
pmr49
Renton, WA
Kubota B
There must be a trick to this. I just acquired this vehicle with low hours. I have been dumping dirt and clay out of the dump bed (manual), maybe 300 pounds at a time, keeping the weight toward the rear to get some leverage. Last trip out I perhaps had too much weight toward the back so that the latch wouldn't release. I then pulled the load out by hand until all the dirt was off the back portion. The dirt in the front made it hard to lift, but I managed. I let the bed drop back into place and now the bed won't release at all. Anyone else have this issue? If so, what to do? Thanks in advance.
   / 2004 John Deere Gator HPX release latch for dump bed is stuck #2
Spray latch parts with PB Blaster, Kroil, Liquid Wrench or another penetrant. Tap latch lightly with a mallet. Let penetrant soak overnight. Tap latch with a mallet again. Should unlock.
Lubricate latch with a spray lubricant. Wax lube does not hold dust. Lithium grease fine for this application. Penetrant is NOT lubricant.
   / 2004 John Deere Gator HPX release latch for dump bed is stuck #3
DITTO above, may try pushing down on the bed to.
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A55314)
2022 Schulte...
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
2015 Chevrolet Silverado Pickup Truck (A55314)
2015 Chevrolet...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2023 G Bar K Goose Neck Flat Bed (A55218)
2023 G Bar K Goose...
