2004 HST L5030 is a no go Kubo
   / 2004 HST L5030 is a no go Kubo #1
flynlo21
Northwest AR
2004 Kubota L5030 HST
My HST 5030 has got me vexed. I hauled hay (round bales) last week and when I parked it all was well. Monday night I started it, warmed it up for 5 minutes, increased engine rpm to 2000, and pressed the forward pedal. It immediately died and I heard a clicking sound somewhere on the right side of the engine.
It started right back up, but when I pressed the pedal, it died and clicked again.
It will idle, lift the hydralics (fluid is full and clear), and rev to whatever, it just dies every time I push down on the pedal. Kubota suggested a fuel filter, which I changed. Problem remained. Now they are talking hydraulic pump, which I pray is not the case.
Any ideas?
Thanks much,
Larry
   / 2004 HST L5030 is a no go Kubo #3
Seat safety switch? Maybe it thinks you're not on the seat...
Mike
   / 2004 HST L5030 is a no go Kubo #4
seat switch would also be my guess.
   / 2004 HST L5030 is a no go Kubo #5
It was worked too hard the last time out and just wants a rest!:D:D:D
One of the safety switches may be overworked and under contacted!:D
It's hard to imagine the thing wouldn't realize my fat butt is not crushing it, but perhaps I've over-crushed it:eek:
   / 2004 HST L5030 is a no go Kubo #7
Check the seat switch. If my switch is not made click off it goes when you hit the go pedal, let up and it runs.
Guys, thank you sooo much. It was the seat switch!!! I can't believe it. I thought maybe hydraulics. TBN rocks.
   / 2004 HST L5030 is a no go Kubo #9
Better give that Kubota dealer a wide berth in future. I'm no expert but even my first guess was a seat switch.
   / 2004 HST L5030 is a no go Kubo #10
Mine does that all the time. The seat switch got bent and easily moves to the off position like no one is sitting down. It will cause some tense moments until you figure it out for the first time.
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A49461)
Miller and Smith...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A50854)
2013 XLR...
GENERAC MAGNUM LIGTH PLANT (A50854)
GENERAC MAGNUM...
2016 CAT 289D SKIDSTEER (A50854)
2016 CAT 289D...
