2004 2500HD gas reduced engine power?
   / 2004 2500HD gas reduced engine power? #1
tylertown
MS
Massey Ferguson 40 backhoe, Ford 5000 general purpose
hi i am having some trouble with my 6.0 2500hd
no problems with the truck at all. runs great but yesterday i left home maybe 3 miles down the road it said reduced engine power and could hardly accelerate. i shut it off and started back up. went about another 2 miles before it did it again. leaving work no problems until the next morning
it did it again.
but when i pulled my machine roughly 12k trailer and all i had no problems. acts like it never happend. and pulling about 3 to 4k rpm. what could cause this to happen at low rpm running 40mph?
any input is greatly appreciated!!
   / 2004 2500HD gas reduced engine power? #2
How long since fuel filter was changed??
   / 2004 2500HD gas reduced engine power? #4
I have the same truck. The fuel filter is in the tank, I believe it's before the fuel pump. I believe the thinking was that by having the filter before the pump rather than after (like the earlier models) the pump wouldn't have to work as hard. I have 132,000 miles with no issues (yet).
Could it also be one of the coil packs?
it doesn't have a in-line fuel filter the only filtering it has the sock on the fuel pump it self in the tank..
They are fine trucks I really like mine. but this problem has me scratching my head. the reduced engine power things comes on without any kind of syncranization it comes on at low rpm cruising speeds not to familiar with electronics but I do know that a sensor of some sort could cause this but have no idea where to start. those low end code readers at the auto parts house don't pin point anything. someone told me that it could be the igniton or the "brain box" but those answers don't seem logical to me because if the thing is cranked and running ignition is out of the picture
but the computer may be bad but I have heard of a few people who have replaced the computer in a few different model trucks and never fixes the initial problem. I don't know where to start. maybe the more it does it I can pin point some type of diagnosis question but this is all I have got right now..
   / 2004 2500HD gas reduced engine power? #7
You need to scan for dtc's. this is usually caused by the throttle body and/or the connector that plugs into it. There is an extended warranty on some vehicles.
thanks I scanned it and it came up with a problem with throttle body actuator
   / 2004 2500HD gas reduced engine power? #9
If you got one or more of these dtc's p0120,p0220,p1516,p2101,p2135 there is a bulletin to replace connector pigtail at throttle body.I would start there. Cheaper than a throttle body.Connector must be soldered and shrink wrap. no but connectors!
thanks! cause I would've of sure used connectors! haha thanks im going to look into the pig tail today!
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
2007 CHEVROLET C4500 DUMP TRUCK (A51406)
2007 CHEVROLET...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
JOHN DEERE Z997R LOT IDENTIFIER 227 (A53084)
JOHN DEERE Z997R...
