2003 TC33D ELECTRICL PROBLEM
/ 2003 TC33D ELECTRICL PROBLEM #1
bigdawg1230
kingsport tn
tc33d
2003 TC33D ELECTRICAL PROBLEM HEADLIGHTS
Hello,
This weekend I turned on my headlights on my TC 33d Tractor. In just a few moments the thing shut off, Just like I had turned key off. After setting a few moments it seemed like a circuit breaker reset, and I had power again. I turned lights on again same thing. I did a battery test it was fine, I also checked ground on frame, its ok, its only doing this with headlights, Has anyone had this happen with there tractor, Thanks, Bigdawg 1230@MSN.com
/ 2003 TC33D ELECTRICL PROBLEM #2
This is a 5 year old post, but my tc33d is doing exactly the same thing. What could it be? If you are still there, bigdawg, did you find the issue?
2017 Hino 155 16ft. Box Truck (A64556)
2017 Hino 155...
Work Saver 3-Pt Finish Mower (A66408)
Work Saver 3-Pt...
New/Unused 12 Ton Hydraulic Jack (A65583)
New/Unused 12 Ton...
2017 International WorkStar 7500 Tri-Axle Dump Truck (A64556)
2017 International...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
