2003 tc30 value? Need help/input
   / 2003 tc30 value? Need help/input #1
jeeperjoe
I'm looking to buy a 2003 TC30 this weekend, 4wd, 145 hours with 5 ft FEL.
Kept up well everything works correctly but am unsure of value of this machine. I am in the central VA area and would like some hlep here before a make a final offer. Thanks to any responses.:eek:
   / 2003 tc30 value? Need help/input #2
You can buy a gear TC30 from Corrihers for around 14K with loader. A hydro unit is around 1K more. You need to see what kind of loader is on it. I know that Corrihers low balls on the loader with a small bush hog brand. A NH loader is gonna be more. Find out what kind of loader is on it and price it out new from you local dealer. I would then try to get the unit for 20 to 25 per cent less than new retail. Good luck.
   / 2003 tc30 value? Need help/input #3
I sold my 2004 model with 120 hours with a NH 7308 FEL, R4 tires, 9x3 transmission, tire chains, and a work light for $11,900 in December.
This has a 7308 loader, 9x3 and i believe a hydro. Folks are in a bit of money trouble but I'll go ahead and say, they're asking $9800. I checked it out today and it is absolutely perfect condition.
Thanks for your inputs, guys.
Joe
   / 2003 tc30 value? Need help/input #5
Joe
I hope you have bought the tractor already. My dealer was going to give me $10,000 for my tractor if I traded it on my new tractor. Does the seller owe on the tractor or is it paid off?
   / 2003 tc30 value? Need help/input #6
Joe
You better jump on it. I gave $7K and a YM1700 Yanmar for a NH1720 that was pristine with 245 one owner hours. I got a box blade to boot. I valued the tractor @ $9K. If I add a 7308 loader for it that's going to run over $3800 more. At $9800 they are trying to move the unit. I've got a feeling that they may just be trying to get out of the unit what they owe. If you really want it offer $9500 and then give the $9800 if they won't budge. Never hurts to dicker a little.
   / 2003 tc30 value? Need help/input #7
jeeperjoe:
Welcome to TBN :D! Jump on it quick; then tell us about your property and intended uses and we will help you spend the money you "saved" on other attachments ;). Jay
   / 2003 tc30 value? Need help/input #8
If it is a hydro, I'd jump on it. If it is a gear, probably jump on it as well.
If I remember correctly, the gear unit had the shift up near the steering wheel with 2nd and reverse in line, for quick directional changes. It also left a fairly flat operators platform, for easier on and off. Seemed like a good idea to me.
Thanks again for all the responses. I've got almost 15 acres, wooded on 13 which I'm clearing. River on two edges of the property so I can't work too close to it. Will be used mainly to box blade up old dead fall, small rocks general debris, grading, and maintaining 550 feet of gravel driveway, backfilling around a new house addition and an under construction 3 car garage.
I had planned to do exactly what ya'll suggested, offer $9500. I think they are just trying to get close to payoff since the owner has relocated to 2 acres and don't use it now. Its nice to be so warmly greeted and encouraged by those in the know. I guess my biggest question is lube maintenance as it applies to general lube points and specifically the 3 point eyelets. I own a couple old Lincolns and am kind of a lube nut. Like stuff to work smoothly and stay corrosion free. Thanks again.
Joe
   / 2003 tc30 value? Need help/input #10
Joe
Joe:
It sounds like you will need an 8' landscape rake and 7' backblade as well :D! Tell us more about your projected long term needs and projects and we will help you spend even more money :cool: Jay
Roose Hog Cart (A50515)
Roose Hog Cart...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A52748)
New Lewis Brothers...
2012 RAM 5500 (A52472)
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
24in Tractor Backhoe Bucket BT4555 (A52748)
24in Tractor...
