2003 LT2000 Intek V Twin 22hp Problem
   / 2003 LT2000 Intek V Twin 22hp Problem #1
nhseller
Derry, NH
Craftsman LT2000
I was mowing early this past season with my 13 year old Craftsman when I hit a wellhead cap that was just protruding from the ground. I knew it was there and thought I would clear it but the deck was just low enough that I hit it. The engine stalled but restarted. A few minutes later the engine began knocking and losing power. I shut it down and restarted it but same issue so I pulled it next to my garage and parked it.
I suspect connecting rod damage. Am I on the right track? Anything else? How easy would this be to repair?
I ended up going to my local Tractor Supply and buying a new Cub Cadet XT1 but I also use my Craftsman with a snow blower attachment so I would like to repair it and dedicate just for winter use.
Thanks for any suggestions.
   / 2003 LT2000 Intek V Twin 22hp Problem #2
Before I would go any farther I would check the key on the flywheel to see if it is partially sheared. This would through it out of time and cause some rough running.
Thanks for the info. I will check that out.
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
Case 1280 Tractor (A53117)
Case 1280 Tractor...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
2015 Mitsubishi Outlander Sport SUV (A53424)
2015 Mitsubishi...
