2003 GX345 Plastic cam?
   / 2003 GX345 Plastic cam? #1
Heinlein0311
Lexington va
John Deere GX 345, John Deere 3320
Hey, first post here. I purchased a 2003 JD gx345 recently from a John Deere certified mechanic. It's been smoking pretty badly and I took it to him, he said he thought it was a clogged breather so after cleaning that and replacing the reed valves it continues to smoke. Now he's thinking the rings are bad. Is that an expensive fix? Does this fix sound legit? My more important question is the mechanic doesn't know if the plastic cam has ever been replaced with the steel one and if it hasnt than he says I should look into getting that replaced as well. This lawnmower has the kawasaki 20hp liquid cooled engine (fd611v). I thought those engines had the steel cams. Am I right? It's got almost 1200 hours on it so I figured if it was plastic that it would have already broken.
   / 2003 GX345 Plastic cam? #2
:welcome: to the forum.
Likely someone here will be able to give you some help and assurance.
Doesn't sound like the "certified" mechanic is very interested.
A compression test should give a ring report for you.
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
2011 GR TRAILER GOOSENECK (A50854)
2011 GR TRAILER...
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A49461)
2005 Ford F650 SVI...
Terms and Conditions (A47384)
Terms and...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
