2003 F150 Transmission issues.
   / 2003 F150 Transmission issues. #31
Starting to think it is time for a Nissan Titan! (Used. I do not buy new trucks).
Because your truck is having an issue at 125k, you are willing to switch brands?
   / 2003 F150 Transmission issues. #32
I don't know the Ford ECU software well.
I do know that ECU's in general are often programmed to allow for a "rolling miss". I think the main reason is to avoid a nuisance CEL code, when somebody gets a tank of sub-standard fuel. In a case like that, the ECU is plenty fast enough to catch the miss, but since the problem clears up with the next tank of decent fuel, the manufacturer does not want a customer (esp. within warranty) coming in with a CEL light on just because of bogus fuel.
Could be a bad plug (not sure if your's have been changed or are still original), coil, or even the connector at the coil. Around here, we see connector corrosion on everything that drives on the road.
Coils can be a real PITA, esp. when they do not totally fail.
You mentioned that your ATF level is high (I think). If it is, try dropping it down to the proper level, allowing for if the fluid is at operating temperature. (Some sticks show both Hot and Cold levels, can't remember what those Fords do).
I'm a fan of changing Trans fluid and filter no later than what the factory spec is, so I'd do that anyway, but I'd be curious to see if it just a matter of too much ATF first.
Rgds, D.
Well, its a long story. I've always been a Nissan guy (we all have a preferred brand). But when I needed and bought this truck (2003) neither Nissan nor Toyota made real full-sized trucks. I've never loved this truck and there are lots of things I've never liked about it. I had to replace the AC system after 5 years to the tune $900 and the rear window has leaked for years and it smells like mildew inside. It has never had adequate shocks (in my opinion) or brakes (in my opinion) but I could have easily taken care of that if I'd wanted to so I can't really complain. The suspension is too wallowy off road. Fine on highway. The steering is one of my biggest complaints. It is terribly vague and sloppy. Interior was cheap and rattly from day one. Trim pieces fall off. When it is in 4wd it is hard to turn (off road of course). At low speeds the throttle is like an on/off switch. It is hard to do anything precisely (backing or hitching to a trailer for instance).
Having said all that, it is comfortable to travel in, even long trips. I've never had any serious engine or mechanical problems. Nothing (mechanical) has ever leaked. It burns a little oil but replacing the PCV recently might help that. It has never once had or needed a front end alignment and I'm only on my third set of tires that still have 10k miles left in them and the middle set was used. Tire wear has always been uniform. That is hard to beat. It has plenty of power. Towing horses, tractors and cars has been trouble free. It has done everything I have asked it to do. It goes from episodes of hard use and abuse to long spells of no use. My kids grew up in it. Both drove it. My daughter still loves it like a pet and wants me to give it to her even though she is married. There has been no rust. So, in this regard it has grown on me and there is nothing like a beat up smelly truck that you don't have to worry about. If and when I let it go I will be sad.
But, I do some hauling of my car to the track. Usually not more than 3-4 hours away but I need to be confident that it will not leave me stranded. If I can get this problem sorted out I'll keep on going. However, I usually sell whatever I'm driving when repairs bills mount and reliability goes down. Since it probably isn't worth much I might actually give it to my daughter as a farm truck on of these days.
The dip stick does have hot and cold levels. I checked it hot and it was in still all the way at the top of the "Do Not Add" section. Since I'm probably going to do a flush/fill/filter service I'll just check it again after that.
   / 2003 F150 Transmission issues. #35
Can't fault you for wanting to switch after not really loving the truck from day 1. I've never heard of vague or sloppy steering from an F150 of the recent years ('97+). I had a '99 and put 137k on it and the steering was just as true when I sold it as it was when I drove it off the lot with 7 miles. Like you, I sold it because it was starting to cost me money to keep it running. It was our third vehicle at the time as I had just bought a new '05 SuperCrew due to having a second child and not being able to fit all of us in the regular cab any more. After a couple coil packs, tranny, and a few other minor things, I decided it wasn't worth it for a 3rd vehicle anymore and sold it. Man, I still miss that truck! It was my first new vehicle. :(
At any rate, best of luck getting it fixed, and if you do move on, good luck picking a good new ride. Let us know how things come out and what fixes it.
   / 2003 F150 Transmission issues. #36
Hope you get it fixed. I am not a ford guy, but everyone seems to think its something other than the trans.
Im going the other way an say it "could" be something to do with the converter going into lockup mode.
Fordman, some of my complaints about the truck are probably just due to it being a full sized truck (I have always liked small trucks). The steering in all the late 90s to 03s seems vague to me....boat-like....full left rudder helmsman!!! My son-in-law has a 2013 F150 and its steering is much better.
   / 2003 F150 Transmission issues. #38
I was riding with a friend in his Ford Ranger while he was trying to figure out a misfire that happened occasionally. It was not throwing any codes but was enough to cause the truck to shudder noticeably. Then once when it stumbled, he put his fut to the floor and held it. The shudder got worse and then the check engine light came on. It was a coil pack.
   / 2003 F150 Transmission issues. #39
I'm with LD1..Converter is going bad..You are feeling this in od, when the converter tries to going to lock up mode..
That was my 'hunch' all along but I don't know enough about ATs and torque converter to make any sort of educated guess. However, I have not experienced the problem at all in weeks.
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
2015 FREIGHTLINER M2 TANDEM AXLE 24FT FLATBED (A57880)
2015 FREIGHTLINER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Rooster Weathervane (A55853)
Rooster...
2016 INTERNATIONAL LF687 SLEEPER (A57880)
2016 INTERNATIONAL...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
