2002 TC40S 12X12 four speed lever on the dash, heavy shifter resistance when attempting to shift gears
   / 2002 TC40S 12X12 four speed lever on the dash, heavy shifter resistance when attempting to shift gears #1
nickel plate
CA
2002 New Holland TC40S
"S" for standard 12X12 transmission. Problem is that the four-speed right dash mounted shift lever, first, second, third and fourth gear changes are VERY stiff, scary stiff so I generally leave it in one gear position and deal with it.
A couple of years ago I had the shuttle shift forward and reverse linkage break down (easy fix) on the other side (left) below the dash so I'm familiar as to how to get to at least the linkage train. So before I remove the right-side lower panel below the dash, any advice as to how correct this problem?
Swict 78" Quick Attach Bucket (A56469)
Swict 78" Quick...
2003 CATERPILLAR M316C MOBILE EXCAVATOR (A52707)
2003 CATERPILLAR...
Year: 2017 Make: Mitsubishi Model: Outlander Vehicle Type: Multipurpose Vehicle (MPV) Mileage: (A56859)
Year: 2017 Make...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
2014 Ford Explorer AWD SUV (A55853)
2014 Ford Explorer...
CFG Industrial H15K (A56469)
CFG Industrial...
