2002 LK3054 - Fluid leaking out the top of the gear box?
   / 2002 LK3054 - Fluid leaking out the top of the gear box? #1
sw99
Colorado
LS G3038
Mine is a 2002 so the shifter is on the floor area. After getting the tractor nice and warm, I get some fluid oozing out the top of the shifter. It's not much, its just enough for the dirt and sand to start sticking to it. It's hard to tell on my view window but could this be from overfilling? Sometimes it looks like the fluid is on the very top line of the view port and other times I can just see a small bubble on the top of the glass. I wonder if the the PO overfilled it? Any ideas? Thanks!
   / 2002 LK3054 - Fluid leaking out the top of the gear box? #2
Looking at the parts manual it appears there is an oil seal(oil shield) directly under the cover. The manual lists two part numbers; T4240-23871 and T4124-23871 which supersedes the earlier no. However, if I had to guess, the transmission/gear case is overfull; I never fill mine over the middle of the sight glass and have never had an issue
Great thanks for the seal numbers! So far it looks like it has stopped the seeping. Fluid level on the window is still pretty high so I am more convinced that it was over filled.
CFG Industry MX15RX Mini Excavator (A57149)
CFG Industry...
MURRAY PUSH MOWER (A58216)
MURRAY PUSH MOWER...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2013 CAT D3K2 XL Crawler Dozer (A59213)
2013 CAT D3K2 XL...
Zero Turn Mower (A55853)
Zero Turn Mower...
2019 INTERNATIONAL LT625 (A58214)
2019 INTERNATIONAL...
