2002 7360...proud new owner!!
   / 2002 7360...proud new owner!!
Question for anyone that might know....
Being in Colorado I have had to start this 7360 in some fairly cold tems....about 15 degrees being the coldest.
When I turn they key to where I think I should see the glow plug indicator come on, the glow plug light does not light up. I leave it in that position for abotu 5-10 secs anyway and then turn the engine over.
Once the engine begins cranking the glow plug light comes on any the tractor will start after about 4-5 seconds of cranking. A little black smoke comes out at the very first but not anything I would consider unusual with diesels although my experience with them is limited.
Does this sound right? I was under the impression that the lights should come on in the "2nd" position and then go ioff when it is "OK" to crank the engine.
   / 2002 7360...proud new owner!! #12
I recently had the same problem. Eventually, it will fail to start. I think what happens is that one or two of the glow plugs go bad and that eventually takes the glow plug controller with it. I just replaced my controller and four glow plugs. All is well now.
You can find the part numbers and cost in this old thread . It takes about 5 minutes to change the controller and about 1/2 hour to change the glow plugs. If you don't already have a set of 3/8" drive metric deep sockets, then go get a set. /forums/images/graemlins/smirk.gif
   / 2002 7360...proud new owner!! #13
Rozett, any problems since we both replaced glow plugs and the controller? I have not had any with starting. My locking differential quit. The roll pin that keeps it all together fell out. Found it it the bottom of the rear with a magnet. Laced it back in place with some stainless wire, still going.
   / 2002 7360...proud new owner!! #14
No, I have not had any problems. Ziggy starts fine in cold weather, although it is garaged. So far, I have had few mechanical problems of any kind. I have ripped the hydraulic filter or the hose off a couple of times because of stumps. In the spring I will look at a skid plate to protect it.
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
CATERPILLAR CP44 PADFOOT ROLLER (A52707)
CATERPILLAR CP44...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
2011 Nissan Maxima Sedan (A53424)
2011 Nissan Maxima...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
