2001 TC40 will not go in gear
   / 2001 TC40 will not go in gear #1
jimmmy86
dresden,tn.
TC40 new holland 2001
I have a 2001 NH TC40 IT WILL NOT GO IN GEAR WHILE TRACTOR IS RUNNING WHEN PRESSING CLUTCH TRACTOR WILL NOT GO IN GEAR THIS PROBLEM JUST STARTED OWNED THIS TRACTOR NEW FROM THE DEALER THIS IS THE FIRST PROBLEM I HAVE HAD IT HAS 560 HOURS ON IT ANY HELP WOULD BE APPERICAITED .
   / 2001 TC40 will not go in gear #2
Has it been setting a while.
Sounds like a possible stuck clutch.
WAS LAST USED ON 09/01/14
IF IT IS A STUCK CLUTCH WHAT WOULD I HAVE TO DO TO GET IT UNSTUCK
   / 2001 TC40 will not go in gear #5
If the tractor was used as recently as a few days ago, its doubtful that is your problem.
   / 2001 TC40 will not go in gear #6
Have you ever adjusted the clutch pedal? The procedure is in the Operator's manual for my 2003.
Does it feel normal when you step on the clutch?
Is all the clutch pedal linkage in place and looks normal--not bent, nothing stuck in there?
Everything looks normal with the linkage and adjustment rod and clutch pedal arm
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
91013 (A48082)
91013 (A48082)
