2001 LB75 - A squirrel chewed up the electrical wires under the side panel
   / 2001 LB75 - A squirrel chewed up the electrical wires under the side panel #1
kzs644
New hollad lb75
Hi,
A squirrel chewed up the electrical wires.
LB75 starts from key, but no control lights, cannot go forward only backward.
The most important thing would be , to fix the forward backward switch.
Thanks in advance
Kalman
   / 2001 LB75 - A squirrel chewed up the electrical wires under the side panel #2
Is there a question there somewhere? The obvious solution is to splice the defective wires. Hopefully they are color coded to facilitate the repair. If the wires are not color coded you may need to procure a wiring diagram. Did the switch get broken as well?
Most of the wires are color coded. The switch works only one direction (
backward ), I think because the damaged wire. (I need to find the wire)
May I ask a wire diagram or service manual ?
Thanks
Kalman
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2000 MACK CH DAYCAB (A58214)
2000 MACK CH...
2019 Ford F-350 (A55973)
2019 Ford F-350...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
2023 Kubota SVL97-2 Compact Track Loader (A56435)
2023 Kubota...
