2001 LB75 - A squirrel chewed up the electrical wires under the side panel
   / 2001 LB75 - A squirrel chewed up the electrical wires under the side panel #1
kzs644
New hollad lb75
Hi,
A squirrel chewed up the electrical wires.
LB75 starts from key, but no control lights, cannot go forward only backward.
The most important thing would be , to fix the forward backward switch.
Thanks in advance
Kalman
   / 2001 LB75 - A squirrel chewed up the electrical wires under the side panel #2
Is there a question there somewhere? The obvious solution is to splice the defective wires. Hopefully they are color coded to facilitate the repair. If the wires are not color coded you may need to procure a wiring diagram. Did the switch get broken as well?
Most of the wires are color coded. The switch works only one direction (
backward ), I think because the damaged wire. (I need to find the wire)
May I ask a wire diagram or service manual ?
Kalman
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
3 WHEEL ELECTRIC GOLF CART (A55745)
3 WHEEL ELECTRIC...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
