2001 JD790 Tachometer Jumping
/ 2001 JD790 Tachometer Jumping #1
pretendfarmer
WA
John Deere 790
This just started happening the very last time I used it for the season. Any ideas on what could be causing this? The tractor only has 500 hours.
/ 2001 JD790 Tachometer Jumping #2
On my skidsteer, it was an indication (in hindsight) that my alternator was going bad. Eventually the tach just stayed at zero. Happened twice - first time six years after i bought it (new), and a second time almost exactly six years later (just put a new one in last week).
A simple quick check is start the engine and see if your battery voltage is up (charging)
/ 2001 JD790 Tachometer Jumping #3
I believe the JD 790 has a cable activated tachometer. Might be that you have to replace the cable..??
/ 2001 JD790 Tachometer Jumping #5
If you have a mechanical cable try lubricating it - graphite works well. Make sure both ends are secure. If the knurled nuts start to back off the cable may no longer be fully seated.
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
(8) BAR JOIST W/ ENGINEERING TAGS ATTACHED (A63291)
(8) BAR JOIST W/...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
2005 MACK CV713 MIXER TRUCK (A63569)
2005 MACK CV713...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
Kubota M4700 (A60462)
