2001 JD790 Tachometer Jumping
/ 2001 JD790 Tachometer Jumping #1
pretendfarmer
WA
John Deere 790
This just started happening the very last time I used it for the season. Any ideas on what could be causing this? The tractor only has 500 hours.
/ 2001 JD790 Tachometer Jumping #2
On my skidsteer, it was an indication (in hindsight) that my alternator was going bad. Eventually the tach just stayed at zero. Happened twice - first time six years after i bought it (new), and a second time almost exactly six years later (just put a new one in last week).
A simple quick check is start the engine and see if your battery voltage is up (charging)
/ 2001 JD790 Tachometer Jumping #3
I believe the JD 790 has a cable activated tachometer. Might be that you have to replace the cable..??
/ 2001 JD790 Tachometer Jumping #5
If you have a mechanical cable try lubricating it - graphite works well. Make sure both ends are secure. If the knurled nuts start to back off the cable may no longer be fully seated.
