2001 GMC 2500HD trailer wiring
/ 2001 GMC 2500HD trailer wiring #1
KB9UDE
Platinum Member
North of Tower Hill, IL
John Deere 4066r John Deere 2025r
I have a 2001 GMC 2500HD crew cab that I pull my 25ft gooseneck trailer with. It seems to not have any brake lights on the trailer. I have read online that it could be in my turn signal switch?? Has anyone ever found this to be true??
Trailer brakes and all other lights on trailer and truck work fine just no trailer brake lights. I have checked all connections. There is no voltage going back there on the truck.
/ 2001 GMC 2500HD trailer wiring #2
Do the turn signals on the trailer lights work or just the parking lights?
If the turn signal lights work then the brake lights should since they use the same filament in the bulb.
Also, check the fuse box in the truck. Some trucks have separate fuses for trailer brakes / turn signals. A friend of mine had this problem with a Ford. Everything on the truck worked but no trailer turn signals. Turns out he has separate fuses in the truck for the trailer lighting and two were blown..
If everything checks out with the truck but no turn signals or brakes on the trailer then the bulb filaments or sockets may be bad.
/ 2001 GMC 2500HD trailer wiring #3
I assume you have a 7-pin connector since you mention trailer brakes. I would go through with a voltmeter and check each pin while using the ground pin for a ground. Do not forget that if you are checking the turn signal or tail light pin then you need to have the turn signals on or have the lights/brakes on while checking.
Another thing is make sure you have AT LEAST 12 volts. I chased a problem for a while where my lights were not working but all the pins showed voltage. It took me a few minutes (and beers) to realize that I was only getting 11.6 volts to my tail light pin and that is not enough to illuminate the bulbs.
Here is the typical wiring diagram:
/ 2001 GMC 2500HD trailer wiring #4
I would do as others have said and start at the truck with a test light and make sure all works at the 7 way plug. They gave very good advise.
GM does use seperate fuses but not 100% sure on that old of a truck. I know my 05 did because it would blow them frequently. If the trucks plug checks out then it has to be between the trailers plug and the light itself.
Chris
/ 2001 GMC 2500HD trailer wiring #5
my 01 gmc yukon 1500 did that and it ended up being bad ground.. when the brakes engaged there was insuficient ground for the lmaps.. check that.. start at the plug as the others said.
might want to clean up the connectors and grease them.. perhaps install an extra frame to frame quick connect ground wire.
soundguy
soundguy
/ 2001 GMC 2500HD trailer wiring #6
I know it may sound bad but have you checked the fuses. my 2000 GMC has seperate fuses for the 7 pin. I did not know that until last week. Went so far as to "jump" the wires to get the right turn signal on the trailer to work.
Someone told me about the seperate fuses for the trailer connector.
Under the hood with the rest of the fuses and Duh it was blown. Replaced fuse and reattached jumped line. Business as usual then. Just felt real dumb!
"momma always said.......... "
I have checked the fuses and even cut all the splices in the factory harness where someone spliced in a 7 pin RV plug for GN in the bed. Checked wires on the supply (front) side and nothing for brakes.
/ 2001 GMC 2500HD trailer wiring #8
does the controller show it is connected? it senses that thru the brake magnets / brake power line.
soundguy
/ 2001 GMC 2500HD trailer wiring #9
most I know won't power the brake line without 'seeing' the brake magnets..
soundguy
Electric brakes work fine. Everything works on truck, all but brake LIGHTS on trailer
/ 2001 GMC 2500HD trailer wiring #11
So on the truck's plug receiver, when someone holds the brakes on the truck are the truck's brake lights coming on? If so then what is the voltage at pins 2 and 5 when the brakes are ON?
This is when it's nice to have another trailer or a friends trailer to hook up and see if the problem is the trailer or the truck.
/ 2001 GMC 2500HD trailer wiring #12
you can also get a plug that goins into your 7 pin and tells you which pins are powered / when.
I'd still check the ground issue for the lamps.
soundguy
/ 2001 GMC 2500HD trailer wiring #13
I just had this very issue come to me last night. The rear lights on the trailer would not work. It was on a 2004 GMC Yukon XL. As SoundGuy suggested on this trailer it was a bad ground. Fount that the wire was simply stripped and put under a bolt on the trailer. Not even a ring terminal.
I started my trouble shooting by first checking the Yukon with my 7 pin test box. It was ok so on to the trailer. I again have a text box and applied 12 volts to the circuit with no lights so started checking things over.
Chris
OK guys. I found out that both my trailers have no brake lights, but all other lights work. On my HOPPY 4 pin test light plugged into a 7 pin adapter it shows brakes on both LT and RT...SO do I have a bad ground or whatcha think??
/ 2001 GMC 2500HD trailer wiring #15
Did both work before? If so its possible you have had a bad day and both have a issue. Again start at the front of the trailer and work toward the rear. Look at the grounds.
Chris
Yes both worked and they still do on other trucks
/ 2001 GMC 2500HD trailer wiring #17
It had to be in your trailer. Check the grounds. Start at the tongue and make sure the white ground wire has a clean/no paint/connection with a good ring terminal. Same thing on the lights themselves. I just fixed a GM truck trailer combo last night that came back to being bad grounds at the lights themselves.
Chris
/ 2001 GMC 2500HD trailer wiring #18
I use a set of jumper cales to go from fram to frame.. metal to metal.. if lamps suddenly work.. you know it is ground.
soundguy
/ 2001 GMC 2500HD trailer wiring #19
that change is usually the power and brake power line..
soundguy
/ 2001 GMC 2500HD trailer wiring #20
One other thought is to actually check the voltage at the rear of the truck. It may be low but yet enough to light up you little tester. It will only take a few minutes, a helper, and a volt meter. Make sure you use the ground pin in the plug and not another ground on the chassis so you can get the real story, not just part of it.
Chris
