2001 Bobcat 873 dies when is not level?????????
   / 2001 Bobcat 873 dies when is not level????????? #1
lawnboy83
Louisville ky
bobcat 873
I have a Bobcat 873 that dies everytime its not level. Loading and unloading from trailer. This is getting to be aggravating I changed every filter today hoping that might fix it but still does the same thing. Please any help would be greatly appreciated.
   / 2001 Bobcat 873 dies when is not level????????? #2
Fuel pick up tube is broken or cracked in tank.:thumbsup:
How big of a job is that to replace?
   / 2001 Bobcat 873 dies when is not level????????? #4
Fish it out with a wire and stick a new one on.
   / 2001 Bobcat 873 dies when is not level????????? #5
How big of a job is that to replace?[/QUOTE
fuel pickup and fuel return hoses go into top of the tank somewhere between the engine and hydrostatic pump (actual location was moved a couple times throughout production of this model due to design changes). Usually it is tuck up close to pump. The barbed fitting going into the tank passes through an expandable rubber bushing. To Remove; pull up and twist the bushing. It will pull out. Use a new bushing when you reinstall. If the pickup tube is hard straight plastic type most dealers replace it with hose about 1.5 - 2 times longer than original tube and install p/n 6650239 brass fuel screen on end of hose.
Thanks for all the help greatly appreciated
   / 2001 Bobcat 873 dies when is not level????????? #7
Check the oil level. Might have a low oil shutoff.
2017 Claas Jaguar 860 Forage Harvester (A52128)
2017 Claas Jaguar...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A51222)
LINK BELT LB-98...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
2016 Takeuchi TL8 (A47384)
2016 Takeuchi TL8...
1996 Chevy 2500 - Cheyenne Edition (A50515)
1996 Chevy 2500 -...
2006 Isuzu NPR 16FT Box Truck (A50323)
2006 Isuzu NPR...
