2000 new holland 2120 hss problem
   / 2000 new holland 2120 hss problem #1
6536jim
skillman, nj
2000 newholland 2120 hss
Hi guys
My NewHolland 2120 hss has about 900 hours on it and has been used mainly to load mulch and grading out for lawn installs.
Starting last year it began cutting out when engaged in forward or reverse. It was like the tractor was shifted into neutral. After
a few seconds it would usually re-engage or I would hit the clutch pedal and move the forward and reverse lever back and worth until
it re-engaged. I have the repair manual, I preformed the hydro service including cleaning the suction screen, new filter and oil. I checked
the forward/reverse/nuetral switch ok. Checked the mode switch ok checked the control box tested out of range. replaced it and rechecked
got the same readings (i am assuming box is ok, just wrong data). I checked the forward / reverse solenoids ok. Purchased fittings
check relief pressure setting and adjusted to factory specs. I checked the cable from the clutch pedal to solenoid pak cable and valve move
ok. At this point it looks like forward and reverse clutch paks are bad. Before I split the tractor is there anything I may have missed? Has anyone
had this problem? I am assuming the hss hydraulic pump is ok because relief pressure is good and all other hydraulic functions ie loader and backhoe operate
fine. Any help or suggestions would be appreciated, thanks.
   / 2000 new holland 2120 hss problem #2
Hi, I am also having HSS problems with my 2120 and I just made a thread about it. How did you test the electronic control box and solenoids? Do you have manual that covers the EHSS version that we have? My 2120 will not start when it has this problem. Thanks.
   / 2000 new holland 2120 hss problem #3
Jim, are you certain the linkage is moving through its full range of motion? Hard to believe both clutch packs would simultaneously quit. I have the trans troubleshooting page somewhere if it would help you.
Jim
Hi Guys,
Thanks for the reply. I went thru the entire flow chart (service manual) for the ehss.
I tested the f/n/r switch mode switch solenoids and control box. The control box is tested using a volt/ammeter. Just follow the manual. I agree that it's strange that both forward and reverse clutches could be bad at the same time.
However when I did the 350 or 500 hour hydro service I found alot of grey clumpy material in the filter
and in the drained oil. Reminded me of a automatic trans with burned up clutches. I also read a tread in another forum where the guy had to replace the clutch paks because the material literally just came off the metal backing plates. One additional note I usually run the machine in the turtle or slow mode setting, just the other day I switched into the rabbit mode (fast shift mode) and the machine performed perfectly, no slipping or jumping in and out of forward or reverse. I only ran it for about an hour, so I will try it again and see how it goes.
Gwydyr, if the machine wont turn over make sure you check the pto lever, on my unit if it is just slightly out the tractor will not turn over. also check the f/n/r switch with the volt meter that can also cause a no start. Thanks guys.
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A52577)
2005 INTERNATIONAL...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
2015 Linde H35D 4,350lbs. Diesel Forklift (A51691)
2015 Linde H35D...
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
