2000 L2500 Kubota, Boom lift up down weird.
   / 2000 L2500 Kubota, Boom lift up down weird. #1
macdoesit
Mitsubishi MT 2801fd Loader
3 point lift arms were not going all the way up, PO had the stop a little before highest point. I readjusted the stop so it would lift all the way up. Several days later I was doing some dirt hauling with the bucket and noticed the boom was very slow going up and down, had to put it in float for it to go down, wth. Not knowing this would have an effect, I lowered the 3 point a tad and the boom up and down started working normal, wth, I put the 3 point all the way up again and boom would not go up and down as it should, so again I lowered the 3 point a tad and the boom works as it should. Does anyone know what is going on ?????
   / 2000 L2500 Kubota, Boom lift up down weird. #2
If the three point is being maxxed out, the system is probably in "bypass" which lowers the pressure.
   / 2000 L2500 Kubota, Boom lift up down weird. #3
Sounds like the 3 point feedback arm is out of adjustment so it doesn’t stop asking for oil when fully raised. Was this what you adjusted?
That model might have the Husco FEL valve with series - parallel flow path. This valve directs oil returning from lift lower circuit to the power beyond circuit so you can lift and dump at the same time. Downside of this type of valve is that any load on the 3 point reduces loader lift and if enough load prevents loader from lowering.
I adjusted the lever right side of driver. PO had the stop set and I moved it further so the arms would lift higher on the 3 point. No weight on the 3 point lift, when at it"s highest the boom arms are very slow up and down. Boom can lift and dump at the same time. If I let the 3 point drop an inch or so the fel boom and bucket work as they should
It sounds like your 3-point hitch is affecting the boom due to hydraulic flow issues. Here are a few possible reasons:
  1. Hydraulic Flow Priority: The system might prioritize the 3-point, reducing fluid to the boom when fully raised.
  2. Low Fluid Levels: Check hydraulic fluid levels; low levels can cause these problems.
  3. Valve Adjustment: The control valve might be out of adjustment, restricting fluid flow.
  4. Load Sensing: The system could be limiting fluid to the boom if it senses the 3-point as fully loaded.
  5. Airlock: There could be air in the system; bleeding it might help.
For detailed guidance, check out Manualskart.com for a service manual tailored to your tractor.
Thank you. I will use the Manualskart.com. My tractor pin number is HK34733 and the closest they have is HK34732.
Thank you
2018 KENWORTH T680 SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
Kubota RTV-X1100C (A51573)
Kubota RTV-X1100C...
BESTWAY AG VSK50 LOT NUMBER 105 (A53084)
BESTWAY AG VSK50...
2019 KOMATSU WA320-8 WHEEL LOADER (A51246)
2019 KOMATSU...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
