2000 john deere 3029d engine blowing oil and exhaust out valve cover tube
   / 2000 john deere 3029d engine blowing oil and exhaust out valve cover tube #1
talltailkennel
Kubota M7060
I have a tractor that is a 2000 with a john deere 3029d engine in it. I was hauling hay and suddenly lost power and started having a lot of really black exhaust. Thought it might be an injector so I changed all 3 of them as well as the oil/filter, and fuel filter. It has better power now and not as much smoke but it is blowing exhaust out the hose that comes off the valve cover. And oil is coming out the dip stick like it is under pressure. Any ideas?
   / 2000 john deere 3029d engine blowing oil and exhaust out valve cover tube #2
Head gasket, valve seals, broken rings, jumped time, bent pushrod. If none of those fixes are in your wheel house, better have some take a look.
   / 2000 john deere 3029d engine blowing oil and exhaust out valve cover tube #3
I was thinking stuck rings or broken ring(s) creating a LOT of blowby
   / 2000 john deere 3029d engine blowing oil and exhaust out valve cover tube #4
Excessive blow by is generally caused by worn or broken rings, burned hole in piston crown, etc that alls combustion gases to pressurizes the oil pan and causes oil to blow out.
   / 2000 john deere 3029d engine blowing oil and exhaust out valve cover tube #5
Stuck open or badly burnt intake valve or valves. Take the valve cover off and check all the valves also check the valve lash.
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
PAIR OF 5' CLIP ON TRAILER RAMPS (A51247)
PAIR OF 5' CLIP ON...
UNUSED WOLVERINE GB-11-72W-72" HYD GRAPPLE BUCKET (A51248)
UNUSED WOLVERINE...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
toro turf sweeper (A50324)
toro turf sweeper...
