2000 JD 4300 Leaking, and spraying hydralic fluid on left front tire
   / 2000 JD 4300 Leaking, and spraying hydralic fluid on left front tire #1
Gary546
Norphlet, AR.
1962 TO-35 Massey Furgerson, 2000 John Deere 4300 HST
I was pulling my driveway, the other day, when I noticed Hydralic fluid spraying on the left front tire. I don't knoww if it's coming from a fitting or a pump.Has this happened to anyone else? searching for answers.
   / 2000 JD 4300 Leaking, and spraying hydralic fluid on left front tire #2
I don't know about how common this is, but you should be aware that hydraulic fluid spray is VERY DANGEROUS.
A high pressure spray of hydraulic fluid will penetrate your skin and can flay the flesh from your bones in less than a second. I have seen horrifying pictures of the results.
If you do not know exactly what you are doing, take this to a dealer or skilled mechanic, no matter what it costs.
   / 2000 JD 4300 Leaking, and spraying hydralic fluid on left front tire #3
Sounds like you have a bad hydraulic fitting or hose and needs to be corrected immediately.
   / 2000 JD 4300 Leaking, and spraying hydralic fluid on left front tire #4
It sounds like you have the infamous battery acid corroding the oil cooler problem. I had that happen on my 4200 shortly after I bought it, and fortunately it was corrected under warranty.
Carefully check for the leak using cardboard, I use drywall shims for that purpose if it's not blatantly obvious as to where the leak is coming from. If you have the old fashioned battery with caps for adding water, then get a new sealed maintenance free battery. You're still stuck going to Deere for a battery as they used an odd size that isn't readily available in the 4200 - 4400 series, or fabricate new battery mounts for a more common battery group size.
Check for acid corrosion on the cables and elsewhere if that is the cause of the leak.
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A51039)
2003 International...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
