2000 ford three point hitch
   / 2000 ford three point hitch #1
Varmint1
Deville,La
JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
My uncles 67 model 2000 ford 3 cyl. gas three point hitch only works if he moves the draft control and then it just lowers back down
   / 2000 ford three point hitch #2
time to buy an fo-31? service manual.. a 15$ top cover gasket and oring kit.. and pull the cover and adjust the linkages renew the orings and gasket..e tc.. might service the filter /oilwhile in that far as well.
   / 2000 ford three point hitch #3
Soundguy- Does a 1963 Ford 2000 have a filter in the 3 point lift system?
Thanks- Oldstuff
   / 2000 ford three point hitch #4
Thanks- Oldstuff
short answer.. no.
long answer: could be.
1, there was a dealer filter option available that used an external spin on filter.. they are exceedingly rare to find on that has that option.
2, if you are running some sort of hyd implement off the tractor hyds, if there is a return filter on that setup.. then defacto.. the system has a filter.
run of the mill 00/01/4 cyl 000 no filter..
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
2014 Chrysler Town & Country Touring-L Wagon (A53117)
2014 Chrysler Town...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
Toro Mower (A50324)
Toro Mower (A50324)
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
