20" wheels on the farm
   / 20" wheels on the farm #1
BruceWard
Platinum Member
Central, AR
I bought a 2007 GMC truck last week. Unfortunately it has 20" wheels. The manual says not to use the 20" wheels offroad. My previous truck had 265/75R16 Goodyear Wrangler Silentarmor tires. I am considering either trading the 20s for smaller wheels or installing 275/60R20 Silentarmor tires.
Do you think the 275/60R20 tires with 6.5" sidewalls will work ok offroad? I frequently find stump holes with tires or drive on less than 6" rocks.
I appreciate any and all advice.
Thanks.
   / 20" wheels on the farm #2
You should probably have a talk with a GMC dealer. There are design considerations that result in that wheel & tire combo on that vehicle. Make sure that you aren't creating an unintended adverse consequence with your proposed change.
   / 20" wheels on the farm #3
I would be afraid of denting a wheel with the small side wall 20's have. I would also be concerned with breaking the bead.
Not sure what size truck you have but my neighbor bought a Chevy 3500 with 20's and he pulls a 5th wheel camper. Looking at the load capacity of the 20" tires there was not enough load capacity for him. He had to get a set of the factory aluminum wheels, I think in 16's, then put on 285's on it.
Also take a look at the Goodyear Duratrac if you like Goodyears. That is what my neighbor has on his 3500 and they are a nice tire.
http://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Wrangler+DuraTrac
Chris
The Silentarmor tires are a little less agressive than DuraTrac.
SilentArmor
Duratrac
The SilentArmor tires have kevlar plys and are rated for higher speed than the Duratrack 119 mph vs 99 mph.
The truck is a 2007 1500. The 2640 pound capacity of the SilentArmor tires is plenty for me.
The truck in this picture has 285/60R20 Duratacks
Looking at it I am thinking that I can live with that amount of sidewall.
   / 20" wheels on the farm #5
I'm not for sure, but I don't think you can get the silentarmours in 20" size. My Dodge came with 20's and I got a set of aftermarket wheels in 18" and got Silentarmours in a taller sidewall that worked out to the same diameter as the 20" tires. Do a google on Tire Rack, they have alot of tires for sale.
   / 20" wheels on the farm #7
When you change the wheel size does that not throw of the speedometer ?
You have to change tire size to match the OEM tire diameter. See here to play with tiresizes to keep the tire diameter the same (or close).
For example a 265-65-R20 tire is almost the same size as a 285-70-R18 one (the 18" tire would make the speedometer read 60 MPH when you are going 60.3 MPH) or a 295-75-R16 one
Aaron Z
I plan to have the ECU reprogrammed to set the speedometer for the size of whatever tire is installed.
Silentarmors are available in 275/55R20 (oem 32"), 275/60R20 (33"), 285/60R20 (33.5") and 305/60R20 (34.4"). The 285s and 305s are way to expensive for me.
But my big issue is whether to stick with the factory 20 inch wheels with a little bigger tires or buy 18" wheels for 275/70R18 (33.2") tires. I am starting to believe the 20s with bigger tires may be ok.
   / 20" wheels on the farm #9
Make sure you rim width is in the range of the tires. I think anything bigger than 285 will give you issues.
Chris
   / 20" wheels on the farm #10
This is personal opinion for years of Jeeps, and 4x4 trucks. Lots of wheelin, plenty of rocks(Rubicon ect).
Get a set of 16" or 17" and a set of 285's or similar with some sidewall to them. If you really use it off road, maybe even steel rims. 20's are a pretty street tire, for some I guess. Off road though? I would tear those rims to shreds out hunting. I can't take my full size long bed xcab truck where I took the Jeeps, but it still gets used.
Make sure of your brake size; a 16" may not clear your rotors.
Also make sure the rim/tire combo is ok for the weight you may carry or tow.
I like the Cepck mud tires I have now(almost ready for a new set. 285's on factory 16" rims. As big as I want to go, especially since the truck already sits high stock; my 5th wheel has the axles flipped so it is taller to fir the truck already...
New Holland TN60A (A50120)
New Holland TN60A...
Ezflow 500 Gravity Box W/Cart (A50774)
Ezflow 500 Gravity...
2013 Chrysler Town and Country Van (A50324)
2013 Chrysler Town...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
PORTABLE INDUCTION HEATER (A52472)
PORTABLE INDUCTION...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
