-20 series tractor steering shaft coupler with PS
   / -20 series tractor steering shaft coupler with PS #1
bill_396
On my 2420D with power steering the flex-joint/spline shaft coupler just above the steering gear box is used up. It has 3 ball that run in grooves in the housing, the balls are rusted small and the lengthwise grooves in the housing are worn into a track all the way around allowing the steering wheel to just spin. Is this part available and if so from where? Info on the -20 series tractors power stering system is hard to come by. To keep me going I shimmed the balls and raised the point that they contact the housing to get better contact but next time it breaks I really will be done and would like to have the part by then. thanks.
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
LMC LOT IDENTIFIER 128 (A53084)
LMC LOT IDENTIFIER...
2023 JOHN DEERE 333G LOT IDENTIFIER 242 (A53084)
2023 JOHN DEERE...
RIGID TOOLBOX (A52472)
2017 CATERPILLAR 12M3 MOTORGRADER (A51246)
2017 CATERPILLAR...
