-20 series tractor steering shaft coupler with PS
   / -20 series tractor steering shaft coupler with PS #1
bill_396
On my 2420D with power steering the flex-joint/spline shaft coupler just above the steering gear box is used up. It has 3 ball that run in grooves in the housing, the balls are rusted small and the lengthwise grooves in the housing are worn into a track all the way around allowing the steering wheel to just spin. Is this part available and if so from where? Info on the -20 series tractors power stering system is hard to come by. To keep me going I shimmed the balls and raised the point that they contact the housing to get better contact but next time it breaks I really will be done and would like to have the part by then. thanks.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
LMC LOT NUMBER 140 (A53084)
LMC LOT NUMBER 140...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2011 Ford Crown...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
