2 Wheel Tractors - Buying & Using
/ 2 Wheel Tractors - Buying & Using #21
Gravely...
"There is no brake other than the forward/reverse lever. "
Yeah... I know about this one !
1st time at a Gravely's controls... ~age 10...
...almost pushed my Aunt's 1950's Chevy over because I didn't know how to stop the tractor... went straight into the passenger's door... /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
Powerful tractor... !
Dave...
/ 2 Wheel Tractors - Buying & Using #22
I really enjoy my Gravelys - I've got a 4 speed and 8 speed L model that get year-round use plus a newer Kohler powered tractor that I run the 40 inch commercial mower on. Gravely was founded in Dunbar WV and they deserve all of the credit for the original D model and later L models. Gravely was purchased by Studebaker in the 60's I believe and moved to Clemmons NC where they stayed until the early 90's when production moved to the Ariens facility in Brillion WI. Ariens owns Gravely today but production has ceased on the 2 wheel tractors - new Gravelys today are zero-turn mowers etc.
/ 2 Wheel Tractors - Buying & Using #23
No smoke at all! Mine has no guage, so I don't know what the pressure is. I'll have to look into putting one on. And I guess I should work on the slip clutch clamp bolts. As far as traction goes, I'm keeping the chains on it full time right now - no traction problems with those on!
To20Chris:
<font color="blue">Mine has no guage </font>
Must have been removed. There should be a fitting on the housing about mid way on the port side just below the hood that you can screw into. I would guess (based on other stuff I bought for mine) that it takes a standard guage with english threads (not metric). Should be a simple job. Probably get a guage at NAPA or similar.
JEH
/ 2 Wheel Tractors - Buying & Using #25
Cool - I have a spare guage floating around in a box in the barn somewhere - I bet I could drive up to AutoZone and back faster than I could find it (I won't though /forums/images/graemlins/wink.gif )!
/ 2 Wheel Tractors - Buying & Using #26
There's a company here in the states that imports the 2wd Goldoni tractors. I bought one about three years ago primarily because I wanted a diesel engine (Lombardini). I've never been able to stall the thing. I think it's rated at 12-14hp.
/ 2 Wheel Tractors - Buying & Using #27
</font><font color="blue" class="small">( There's a company here in the states that imports the 2wd Goldoni tractors. I bought one about three years ago primarily because I wanted a diesel engine (Lombardini). I've never been able to stall the thing. I think it's rated at 12-14hp. )</font>
Can you give me contact info. for the dealer here ?
I'm interested in getting more info.
Earth Works has diesel engine options for the larger BCS tractor(s)...
Thanks...
Dave...
/ 2 Wheel Tractors - Buying & Using #28
There are a couple of dealers in the US. Here's the dealer I used. At one time years ago, I believe they were the US distributors for BCS.
EARTH POWER EQUIPMENT INC.
30 East Fourth Ave. - P.O.Box 8396
43201 Columbus, OH - U S A
Phone. 001 614 294 4618 FAX 001 614 294 6014
earthpowereqt@aol.com
Here's a link to the manufacturer's website: http://www.goldoni.com/eng/special.htm
Another builder makes a wagon that when hooked to the Goldoni, turns it into a 4wd ATV. I've heard that for some small farmers in Italy it doubles as the family car.
Here's a link to a picture of the powered trailer.
http://www.ferrari-tractors.com/walking.htm#Fort%20Powered%20Trailers
/ 2 Wheel Tractors - Buying & Using #29
It must be model Super Special. Best machine I ever seen!!!
Congrat on it. I'm jealous /forums/images/graemlins/wink.gif
Btw, this model is produced in HR too, under TPS name, for local market.
/ 2 Wheel Tractors - Buying & Using #30
Does your tractor have 2 speed + ground pto?
If so, you can make 4x4 trailor out or car diff.
Lot of them here are done like that. Factory trailors are offered, too.
Did you know that Goldoni O & V tractors use JD engines, and are rebadged as John Deere? /forums/images/graemlins/cool.gif
/ 2 Wheel Tractors - Buying & Using #31
I'm not sure what you mean by ground speed pto. It does have a two speed pto. I hadn't thought of building a powered trailer. Might be an interesting project.
The Goldoni 4wd tractors are being imported into the US. Other than the Goldoni website, I haven't seen them. Given their low profile I suspect they might be popular in large vineyards. I'm sure the cost delivered here would rule them out for most homeowners. They would be excellent "mountain" tractors in many areas given the design and the availability of hp ratings that aren't normally thought of as being associated with a tractor about the same size as a large CUT. Anything built in this country in the neighborhood of 75 hp is going to be larger.
/ 2 Wheel Tractors - Buying & Using #32
</font><font color="blue" class="small">( I'm not sure what you mean by ground speed pto. )</font>
Ground speed PTO is a PTO that turns at the speed of the tires, like certain spreaders, etc. The faster you go, the faster the PTO turns. Some larger Kioti models offer reg. and ground PTO. John
Darren:
Thanks for the referrals - know a bit about the BCS, nice to see other stuff available in this category. I suspect a lot of TBNers are not familiar with this type of equipment. Many thanks.
JEH
/ 2 Wheel Tractors - Buying & Using #34
Thanks Darren !
I check 'em out...
Dave...
/ 2 Wheel Tractors - Buying & Using #35
I bought a 5665 Gravely (about 1987-1989) with 12 hp Kohler engine about 3 years ago with 104 hours on it. Have following attachments:
o 30" bush hog/mower
o Sulky
o Cart
o MacKissic shredder
o 48" snow plow
o 26" square chute (VERY much earlier vintage) snow blower
o Rotary garden plow\
When I bought it, it had 2 wheels and no brakes. I've since added dual wheels and brakes to it. It was unmanageable on my hills without the brakes as power steering. It also needed more traction and side-to-side stability that the dual wheels gave it.
Initially, it had tire chains on the 2 turf tires. Except on very wet snow or ice, the dual wheels provide more traction that doesn't dig up the ground when slippage occurs. I've since bought 4 wheels and tires with ag tires and have put metal screws into the lugs. These are only for winter time, because they are very much like the tires with chains on them, e.g. dig up the ground terribly when they slip and bounce the tractor around. In general the dual turfs provide more traction, evenly distributed and don't dig the ground up when they slip. The brakes give you another method to get out of a slippage situation, by the way, you just rock the brake handle back and forth. This gets me out of most slippage situations. The dual wheels help A LOT to keep the skinny single wheels from dropping into holes.
The 30" bush hog is my most-used attachment. I basically put it on in the spring and take it off in late fall. With the added crossed blades to replace the sinlge bush hog blade, it makes smoother cuts. The bush hog blade is a little better for really heavy stuff, but not much.
The sulky is great for doing long mowing stretches but reduces the maneuverability for serious bush hogging. It's harder to response quickly to wheel stoppage turning the tractor (when striking something) when on the sulky.
The cart is GREAT for hauling very heavy loads. It's also great for hitching behind the sulky (I added a hitch on the sulky for this) and hauling light loads, like a water cooler for drinking water. There's no room on a Gravely for such stuff.
The most balanced tool is the 48" snow plow. You have to ditch the sulky when using it in wet snow, or else mount the chains again. With or without the sulky it's gotta be the best balanced attachment and probably is what the original owner used it for mostly, as I saw his LONG driveway and his near-impossible-to-mow sloped lawn.
The MacKissic shredder is about worthless without the chipper. I only use it once/year to shred up leaves that I steal from the stupid city folks that don't use them. It also has a ridiculously skinny belt between the PTO shaft and the shredder shaft. I mainly still use my old 8 hp TroyBilt shredder/chipper for serious shredding/chipping.
The rotary plow was great for doing virgin, heavily grassed, soil. It was also good for making mounded rows for good drainage in my veggie garden. Since then, it's been parked, with it's drive end elevated because the seal leaks badly at that end when parked.
I've only needed the snow thrower once. AFTER using it, I found out about the external bearing on the inlet to the PTO shaft. It's supposed to be lubed with grease but best to give it a shot of heavy lube oil. Usage didn't seem to affect the dry bearing. Had to use it to throw about 7" of heavy sleet. Couldn't make it out the carriage house entrance with the snow blade. The snow thrower is AWSOME. It threw that sleet about 50' feet or more high and to the side. Watch out for any windows or open garage doors when using that thing! It's sling gobs of snow/ice into any opening.
Only troubles have been a blown fuse (only has one) because the fuse holder metal ends had recessed and weren't making good contact. Replaced the holder. No problem since. Had to replace the ignition points. They're external, an easy job but required the gap to be set at only 0.016". Otherwise, the points would not close. This is a common Kohler problem. Supposed to be set at 0.020". Engine runs fine at 0.016" but won't start at 0.020" because the points never close. Had to tighten the forward clutch to keep it from slipping going uphill. No problems now. It'll climb a tree if you let it. Engine smoked initially when left to idle very long. Quit this after switch to Mobil 1. Still uses some oil, like a Benz does. I'm suspicious of engines that don't use a tiny bit of oil. The right side wheel seal leaked a little oil after I put the brakes on. Must have disturbed that seal lip a little. One method of getting to the the seals is to remove the 4 bolts that hold on the brake backing plate. Changed the trans oil. Slowed it down to almost nothing. After I bought another wheel seal, the leakage has stopped (new seal is still in the drawer in my carriage house).
Have had to have the ovaled holes on the cart attachment points reinforced with weld and washers, to keep the cart from sagging when it attaches to the tractor via the "Y" hitch.
Ralph
/ 2 Wheel Tractors - Buying & Using #36
The pto can be shifted to either neutral, 546 or 892 rpm. It's not a ground speed PTO. I expect the Fort trailers take that into consideration.
/ 2 Wheel Tractors - Buying & Using #37
Darren,
Your machine should have 3 positions for pto speed, 2 are what you mentioned and 3rd one must be ground.
Wnen I'll have possibility I'll take some pics of machine and powered trailor.
I found in my archive picture of model Super Lux 150, with 2 cyl diesel engine.
/ 2 Wheel Tractors - Buying & Using #38
I'll have to look at it more closely, but I don't think it's a three speed. Maybe that's for the 150 models. Mine's the little 140. Do you have a picture of the gear shifts? That might clear it up.
/ 2 Wheel Tractors - Buying & Using #39
I'll look Darren.
We have here model 140 locally produced, by company TPS. All of them have ground pto. When you shift it in that position, pto stops, until you move tractor forward or reverse. When tractor is in move, pto rotate forward and reverse, too. I mean lower pto, where you attach tiller.
Switch pattern is: SYNCHRO-Neutral-FAST-Neutral-SLOW if my memory is good.
I haven't this machine, and it is my object of desire.
BTW, 130, 140 and 150 have equal, iron casted housings. Attachments are fixed by two M16 T-screws. Is like that on your machine?
Does your machine looks like one on pic?
RalphVa:
Nice review. I found the dozer blade worked real well for snow pushing too (not so good for gravel though).
Darren: Thanks again for the site referral. Finally had a chance to go through it. Very interesting. Amazing how much of this stuff available in Europe - size appropriate for the small operation.
ZJ_HR: Neat pic of Goldoni on the showroom floor. Ummmm.
<font color="blue">Gravely owners site </font>
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
6x12 Utility Trailer (A62613)
6x12 Utility...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
CrustBuster 3800 Grain Drill (A66285)
CrustBuster 3800...
(12) sets of Yetter trash wheels, Coal Valley, IL (A65640)
(12) sets of...
