Snow Equipment Owning/Operating 2 wheel drive
   / 2 wheel drive #1
clancey
atlantic canada
kubota L4200
New to the tractor world and looking for advice. Own a cottage property with almost one mile of driveway. We get quite a bit of snow in our area. I am looking for a tractor for mainly blowing snow, road maintenance (box blade) and hauling out firewood. I am finding that some of the bigger 2 wheel drive tractors are quite a bit cheaper. What do I need. In a perfect world I would like a smaller, newer, 4x4 tractor (28hp) with a loader but dont know if they are big enough to handle the snow. Will a higher hp 2wd tractor handle snow blowing? What is more important, hp or traction?
   / 2 wheel drive #2
Clancy, welcome to the site!
Others with more experience than me will chime in I'm sure, but in my experience with a 2WD Bolens and now a 4WD TYM, go with the 4WD. I don't do snow removal, but in working around my land, the difference in traction between 2 and 4WD is worth the price! MY TYM is a 233, the smallest they make and it does everything I ask of it in keeping up fire lanes and deer food plots plowed and producing.
   / 2 wheel drive #3
4WD (more accurately, 4 wheel assist) would be advantageous, but folks have been doing all the tasks you describe with 2WD tractors for years.
You definitely want chains for the rear wheels with either the larger 2WD machine or the smaller 4WD one.
As far as what's more important, HP or traction...in my case, it's traction, but I don't have a snow blower.
A question...how have you, or the previous owner of the cottage, been clearing out snow in the past?
Welcome to TBN!
   / 2 wheel drive
We have owned the cottage for about 3 years, and my wife & I spend all our free time there summer & winter. It is our paridise. We snowmobile down in the winter, the road hasnt been kept open in previous years. As we will be empty nesters within 3 years, our intention is to sell our primary residence and live there year round. Snowmobiling out everyday isnt practical and we need to keep the road open. Getting lots of suggestions as what i need for equipment and lets face it, its a big investment and i want to buy right. As i said, there are some really good deals on the bigger, older 2wd tractors (ford 7600 for example) as opposed to the newer smaller 4x4 ones. These tractors have around 4000 hrs on them. Is that something to be concerned with?Guess my question is will the 2wd do the job? Or on the other hand, will the smaller (25-30) newer 4x4 be sufficient for that amount of snow. We can get up to 2 feet in a storm not to mention drifts. I live in Atlantic Canada. thanks for the reply.
   / 2 wheel drive #5
This is an interesting call. As said the 2WD tractors can do what you want....but the newer 4wd tractors have more maneuverability and get great traction too. Many have a mid PTO that will allow a front mounted snow blower. They typically are a bit more user friendly for a novice operator.
Big Question: Do you want a snow blower for the front or rear?? With a mile of driveway I think your going to want a front mount. That would lead you to a newer CUT tractor with 4WD and a mid PTO.
The other thing you can do is to put a front mounted plow blade on the tractor and a snow blower on the rear. The blade is faster / more efficient for light snowfalls.....and use the blower for heavy snows or to remove the windrows from bladeing. The best of both worlds IMO.
   / 2 wheel drive #6
Have you determined a budget? Obviously, you'll want to spend as little as possible, but have you come up with a dollar amount yet? Believe me, we TBNers can spend other folks money with no problem whatsoever.
An older tractor might be cheaper, if you can to the servicing and repairs that may be required.
Other then you know you have to clear, is speed a priority? Bigger machine will do it faster, but at a price.
I'm not in an area that gets a lot of snow every winter. But we do get a substantial snow (N'Easter) every few years that can be 2-3 feet.
Per your first post, you wrote you get a lot of snow...and a mile of drive to clear. That is a lot of snow removal, regardless of what sized tractor you get. One thing I strongly recommend is getting out early and frequently enough that you don't have that major snow removal when it ends.
You should consider a cab tractor, by the way...
   / 2 wheel drive
Thanks for the advice both foggy & roy. In a perfect world, i would love to have a CUT with a front mounted blower and a heated cab. I am not really that concerned about speed. My outdoor work (cutting firewood, maintaining my property) is my leisure. My wife and I both realize that to live in our little piece of heaven we need to make some sacrifices, one of them being buying a tractor. Only problem is i consider the tractor a bonus, not a sacrifice.:) Think my next step is to go to a couple of dealers, see what kind of incentives they are offering and decide what i can swing. I think in answer to one of my questions, you are saying that if i do decide to go the CUT 4x4 option a 25 to 30 hp unit should do the job?
   / 2 wheel drive #8
Yeah, 25-30 HP is about the minimum I'd go...and, even though I'm not a big fan of cabbed tractors, that would be a better way to go for the snow removal.Might be a hassle if you intend to use it in the woods though...
   / 2 wheel drive #9
A mile of driveway is a long way to blow backwards with a big tractor with two passes. What's your total snowfall? and does the driveway drift in?
If you have a 4x4 pickup already and your driveway doesn't drift in much, probably a plow for it is best. Especially if you can get some speed up and always push the snow up and over the banks with the plow. If your driveway is very tight and winding then you might have to go to a blower to deal with 5 or 6 feet of snow over a winter or if it drifts in alot.
For in the woods, I'd think 4wd and smaller is best unless you want to make roads for a 2wd farm tractor. If you're just doing 4 cords a year for yourself, even just an ATV will do the job with the right trailer with little trail work.
I'm in a similar situation as you but needed 4wd for my hills and ended up deciding a 40hp tractor do my driveway and move some dirt and still be able to pick my way through the woods without building a highway for it. I did do all my firewood with my ATV before now with no problems and my plowing my 1/4 mile driveway but it was usually very tight in march as I couldn't move snow over the banks.
   / 2 wheel drive
My driveway starts off by going down a hill thru the woods then follows a winding level path beside open fields at the edge of the woods. We get probably 6 feet of snow at least and all of my driveway is drift area so the truck plow option wouldnt work. I have also considered the atv option for getting into the woods as most of my wooded property is waterfrontage along a river and not very deep. Dont really need to get into the woods. My main use for a tractor is snow blowing & road maintenance. Very little of the driveway is actually my property, it is right of way to my property and is used by farmers to access their fields. Having said that, it gets chewed up real bad in the spring and fall with them hauling their equipment in. Not bashing them, they gotta do what they gotta do but if I want to prevent destroying mine & my families vehicles, its up to me to maintain it. Also, i am the only one that has a residential property there so i cant count on any help. By the way, thats a nice tractor you have, cabbed?
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
LMC G300JD LOT NUMBER 246 (A53084)
LMC G300JD LOT...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
Landoll Hauloll (A53472)
Landoll Hauloll...
JOHN DEERE R4023 LOT NUMBER 261 (A53084)
JOHN DEERE R4023...
