2 stroke/PS combo
   / 2 stroke/PS combo #1
browns40
The Real Maine
JD3520
Hi All,
Just wanted to share on my last 10 gallons through the 3520 I have been using 1 oz Wallyworld 2 cycle, and 0.5 oz. white power service per gallon in with the off-road... I had been doing a lot of research based on the truck I bought over the summer, and figured I'd try the mix in the tractor...
I tell ya, she purrs like a kitten--top cylinder lube, higher lubricity, higher cetane... whatever it's doing, the tractor is running quieter, more efficiently, and smoother than ever before...
Not making any suggestions, but figured I'd share what I found...
   / 2 stroke/PS combo #2
My dodge cummins really loves the 2 stroke oil. 1st time I tryed it I thought the motor had died when I took my foot off the throttle at cruise speed. It is really smooth. Kubota seems to be smoother but no where near the differance as the cummins.
   / 2 stroke/PS combo #3
I've used 2 cycle oil in gas and diesel engines off and on for a decade or so but have recently switched to Lucas gas/diesel additive. More expensive. You are encouraging me to go back to my 2 cycle idea. Probably has lots of cleaners in 2 cycle also.
Mike
10 FT Poly Bunk Feeder (A55218)
10 FT Poly Bunk...
2021 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2021 FREIGHTLINER...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2016 KENWORTH T370 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T370...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
