2 stroke engines and operator health
   / 2 stroke engines and operator health #1
freedomlives
Platinum Member
Husak, Slovakia, EU
Iseki TS35F, Goldoni Special 140 with powered trailer -- Goldoni Special 128 -- Goldoni Uno for mowing -- Czech Vari system
Does anyone know if there has been studies of the risks / effects on operator health of using a 4 stroke engine versus a well tuned 2 stroke running a modern 2-stroke oil mix?
I ask because I'm going to Austria to buy a 6 foot drop spreader for lime, and I'm thinking about picking up a walk behind cutter bar mower (because my Czech one goes only 2km/hr, which is less than half of normal walking speed, and this year I have 7 acres of hay to cut), but many have 2 stroke motors.
My experience with 2-stroke motors has usually involved a lot of fumes, particularly the chinese earth drill I have, but since reading this morning, I see that you can buy synthetic oils that are 100:1 or 80:1, so I guess less smoke and fumes? Because it is one thing to suffer a smoky motor for a putting in post holes, which is maybe an hour of total smoke per day of doing fence, which is a few days a year, but something different of many hours of walking miles behind a mower, which is exercise, so my body would be inhaling a lot of the exhaust.
   / 2 stroke engines and operator health #2
good question. can't speak from the research on the topic. to me it's all about frequency & ventilation . if you're a non smoker, so much the better. personally i would not worry about it unless you are right in the exhaust all day long. if you were a welder by trade, well, believe that would be much more of a concern. as far as synthetic oil mix, i use mine @ the manufacturers recommended ratio regardless of oil type.....i sure wouldn't be mixing it lean @ 80-100:1 on a machine designed for 40-50:1. your equipment sounds expensive. if you are that concerned, you might consider a quality particulate mask for paint/chemical use while operating 2 stroke or any small engine for that matter. best regards
   / 2 stroke engines and operator health #3
I use a modern 50 to 1 mix on my string trimmer and chain saw. I never noticed any smoking other than when starting with the choke on. I'm not claiming to be an expert, but I think the mix ratios are based more on the quality and properties of the oils rather than the piece of equipment.
Maybe contacting the oil manufacturers would be a good starting point?
   / 2 stroke engines and operator health #4
A four stroke in poor tune and operating too rich will blow more times than a lean clean two stroke.
   / 2 stroke engines and operator health #5
Both my Stihl string trimmer and Mantis tiller are two stroke and both recommend 89 octane gas and a 50:1 oil mix ratio. I use Stihl's own "Ultra" two stroke oil, which is fully synthetic, so like GaryM, I don't notice any smoke or odor with either machine.
I guess first thing I'm going to try is mixing 50:1 ratio, which is what is printed on the bottle of Husqvarna branded 2-stroke oil I've been using, and see if that improves the smoke situation of the earth drill.
   / 2 stroke engines and operator health #7
Operating a 2 stroke engine outdoors that's constantly moving a machine across a field, I'd have no worries.
   / 2 stroke engines and operator health #8
I would look at fuel consumption as well, particularly with that much cutting.
   / 2 stroke engines and operator health #9
Both are not good for your health, not sure if one is better than the other persay? But I sure wouldn't fall for the manufacture hoopla of running at 80 or 100:1 like amsoil claims or others. Sure some pros have done it and got by but I sure wouldn't. NO WAY. I don't run leaner on mix than 40:1 and like 32:1 normally but no way would I recommend any oil leaner than 50:1......WHY you don't save that much on oil costs, they already run clean. I almost never replace a two stroke plug cause of oil fouling. Why would you want to do that?
   / 2 stroke engines and operator health #10
You realize that people have been operating 2-stroke motorcycles, boats, trimmers, chainsaws, etc for DECADES with no health issues, right? Been riding 2st motorcycles myself for 39yrs with no issues......you're over thinking it.
UNUSED Safety Work Gloves (A53117)
UNUSED Safety Work...
2016 CATERPILLAR 313FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A54313)
2010 FREIGHTLINER...
2011 PETERBILT 384 TANDEM AXLE TANKER TRUCK AND TANKER TRAILERS (A54607)
2011 PETERBILT 384...
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
