2 stage clutch? overrunning pto?
   / 2 stage clutch? overrunning pto? #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Ok, I know that this has been covered somewhere around her probably, but I have a pto question.
With all the differences of live pto, independent pto, 2 stage clutches, etc.. it is hard to figure out exactly what you've got going.
My NH 1920 has I guess a 2 stage clutch. There is a lever that you can flip down to clutch the engine for gear and range changes, but the pto stayes on. You can push through the spring loaded lever all the way, and clutch everything.
With a 2 stage clutch like this, it doesn't seem like an overrunning pto adapter is needed, as the pto is disconnected from the rear wheels at the first clutch point? right?
Soundguy
   / 2 stage clutch? overrunning pto? #2
No, with a double clutch (I call it) you do not need an over running clutch.
2011 Atlas Copco XAS 375JD6 Towable Air Compressor (A55973)
2011 Atlas Copco...
2014 Ford F-550 (A55973)
2014 Ford F-550...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
SKID STEER ATTACHMENT BRUSH WITH BOX (A58214)
SKID STEER...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
