2 hydro pumps vs 1 (Cub Cadet) vs (Kubota)
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #21
Originally Posted by dodge man View Post
I've never had a problem with my BX2350. The only thing I've notice is some feed back in the steering wheel on occasion. Say I raise the deck and when it bottoms out and the pump goes into relief, I will feel a slight bump in the steering wheel, but no loss of power steering. *In my opinion, it is a non issue dreamed up as a sales gimmick.
If there is no benefit to two pumps, then why do all the larger Kubotas have dual pumps?
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #22
I never had such an issue with the BX24 but you always had to have RPMs up to do much of anything with hydraulics.
Where as the B2320 it can be at idle and all hydraulics works at nearly full speed. It so happens to have dual pumps.
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #24
Funny how so many never felt the "need" for dual pumps until someone else came out with them. Sales "gimmick" or not I will be surprised if we don't start seeing them as standard.
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #25
:confused: I thought Yanmar was building the small JD's, now they are building CC's?? :confused:
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #26
Yes, there is a current thread on this on the John Deere Forum speculating if and what the Yanmar engine will be replaced with.
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #27
I must be strange. The number one improvement I'd make on my bx2230 is either a bigger pump or two pumps. I do a lot of heavy FEL work moving rocks and dirt around a New England hill. When I'm using the FEL near it's limits, the PS fades. Not a little either. It can disappear. If I max the hydraulics with the loader and the pressure relief valve opens, the PS is gone. Many times I will have to back out and approach a load differently because I can't turn and load at the same time effectively. And before I'm asked, I've checked both the pressure and flow on my tractor. They're within spec.
If you're going to routinely put heavy demands on the hydraulic system, two pumps can make a difference.
That being said, I don't think I'd let one or two pumps be the sole decision maker between Kubota and Cub Cadet, but it would be a factor for me.
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #28
I must be strange. The number one improvement I'd make on my bx2230 is either a bigger pump or two pumps......snip...
I think the advantage of two pumps is that way they can each pump on completely separate circuits. No crossover.
JD solved the problem of one circuit scavanging flow from another by going to a closed center hydraulic system which then allows a variable displacement pump and a pressure storage vessel called an accumulator. Has anyone here ever tried that? Is that attractive?
rScotty
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #29
:confused:I thought Yanmar was building the small JD's, now they are building CC's?? :confused:
Yanmar was building 1 tractor with green and yellow paint and sticking JD labels on them.
Today they are they are building 1 tractor and are painting some of them green and yellow and putting JD labels on them and painting the rest of them yellow and black and sticking CC labels on them .
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #30
Now this is what I like seeing from you LB. An understandable informative answer. Much better than Me to. OK. 1...2...3...I've got 2 or I've got 3. You've messed up...now we know you can do it.:)
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
Enclosed Service Truck (A55788)
Enclosed Service...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
