2 Hours of Fun
   / 2 Hours of Fun #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
Well, I finally got around to completing 2 of the items on my 'Honey Do' list today. We made the mistake of using plastic, step in posts around our riding ring. We covered them with white plastic pipe topped with T fittings then ran 1.5 inch white electric fence tape between the posts for decoration. Since the ring is inside our fenced in area, there was no need to electrify it. Plus since it looks like the same tape that is electrified, the horses leave it alone. Why were the step in stakes a mistake? The metal rod that is at the bottom is not very long and therefore does not go into the ground very far, plus the connection between the rod and the plastic is a weak point and breaks easily. Several had fallen over and we had been replacing them with metal T posts. Before I got my TC25D, I had set several T posts by hand using one of those contraptions with a tube that drops down over the T post and handles on each side. Lift, slam down, lift, slam down. Darn, a rock is in the way. Pull the post out guess at a new spot. Lift, slam down, etc. Quite a workout.
Last night my my dearest reminded me that four posts needed replaced and, oh by the way, could you please move the manure pile so it's not in the way when I turn the trailer around? OK, dear, but I'll use the tractor FEL to set the posts and I'll need your help with making sure the FEL is centered on the post (we used the hand T post setter to protect the bucket). "How are you going to use the FEL to set the posts?". "Trust me.", I said, confident of the information I received right here on TBN!
As luck would have it, there were no rocks in the way when we set the first post. I lowered the bucket and the post slid into the ground just as slick as could be. I kept an eye on my wife's face (she was standing off to the side after getting the bucket centered) as this was happening. It's good the flies are gone for the season cuz she would have caught a few when her mouth dropped open. /w3tcompact/icons/smile.gif While some of the other T posts needed slightly relocated due to rocks (even the FEL method wont drive them through rocks!) we were finished in about 15 minutes. Great fun! On to the manure pile!
I didn't have to move the pile very far, only about 10 - 15 feet, but it was far enough away that I couldn't just push the pile to its new location. The pile (manure and pine shavings) was about 5 feet tall and 25 feet in diameter. (see attached picture) The ground wasn't muddy, but I still needed 4wd. The 'suicide knob' (thanks for the recommendation, Muhammad!) was invaluable in using the FEL. Since I could not get completely around the pile due to some standing water, I got to use the bucket to drag the manure backwards where I could fill the bucket. I also used this method to smooth out some of the tire tracks (R4s) when I was finished.
I still have to think which way to move the joy stick in order to move the bucket/FEL but I was getting better as the original pile disappeared. I also discovered that if the bucket is not in float position, it can dig into the ground pretty good and pretty quickly. Oops, dump the dirt back into the hole and smooth it out by back dragging the bucket.
So in 2 hours I had set four T posts, moved a manure pile and cleaned the tractor (clay is sticky!). Great fun and great learning!
   / 2 Hours of Fun #2
Mike,
Glad you're enjoying the nice weather. Does the grass stay that green every winter or is it from all the fertilizer./w3tcompact/icons/smile.gif
Man that's a big pile of... never mind.
   / 2 Hours of Fun #3
Does your attachment have an "odor" or is it just me? Mike, your post stinks! ...and furthermore... /w3tcompact/icons/shocked.gif/w3tcompact/icons/wink.gif/w3tcompact/icons/laugh.gif
JimI
   / 2 Hours of Fun
Well, now that I think of it.../w3tcompact/icons/smile.gif
Actually, it doesn't. It's a mix of pine shavings and horse manure that has been sitting for about a year. It looks almost like peat moss.
   / 2 Hours of Fun #5
But how often do you really get a chance to tell someone his post is full of s_ _ t? ...and you may be the only person to actually post a picture of it. /w3tcompact/icons/wink.gif Muhammad should give you a special award for that one./w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif There's the Emmy and the Oscar. Maybe he could call this the "Pattie"./w3tcompact/icons/shocked.gif
On a serious note, I opened your photo hoping to see a picture of you driving T-posts with your loader. If you do it again, do you think you could get your wife to snap the shutter while she is standing clear? Your description is good and it's got me thinking of how to rig a fitting to clamp the post driver onto the loader bucket.
JimI
   / 2 Hours of Fun #6
JimI, your tractor may, and Mike's obviously did, put t-posts in the ground, but I wouldn't count on it too strong in our area. I watched a fellow with a big TLB push t-posts in the ground with the front end loader here when the ground was pretty damp; looked great, very easy. So later I tried it with the bucket on my B7100 when this clay was dry and didn't even get the post an inch in the ground; just picked up the front wheels on the tractor./w3tcompact/icons/frown.gif/w3tcompact/icons/laugh.gif
   / 2 Hours of Fun
I'll get that picture next time. I am sure more of the plastic posts will break.
I used the flat area on the bucket between the bottom and back (did that make sense? see *) to push the stakes in. I lowered the bucket to push the stakes, as opposed to rotating it.
<pre> ______
______/*
</pre>
   / 2 Hours of Fun #8
I put in post the same way as Mike. Still need the driver over the post to give more surface area and stability when pushing the bucket down. Obviously the softer the ground or bigger the tractor the easier this is. If you're ground's too hard you could get a load of dirt in the bucket first. Should give you about another 600lbs of down pressure. That's a lot of PSI on the end of a little T post!
   / 2 Hours of Fun #9
Okay, I'm starting to get the picture; no bucket curl, just the horizontal bucket bottom pushing down. Sounds like it could work most of the time if your ground isn't too hard or you hit a rock as you said before. /w3tcompact/icons/cool.gif
JimI
   / 2 Hours of Fun #10
Actually this is more my fantasy than any reality, but I was thinking of attaching the t-post driver somehow to the bucket and then Bam! Bam! Bam! drive 'em down. Probably tear up my tractor driving a $2 t-post with my luck./w3tcompact/icons/crazy.gif/w3tcompact/icons/laugh.gif
JimI
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51242)
2019 CATERPILLAR...
UNUSED FUTURE QUICK ATTACH FLAIL MOWER (A51244)
UNUSED FUTURE...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
