2 dual acting cylinders on a blade?
   / 2 dual acting cylinders on a blade? #1
radman1
Elite Member
midwest
JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
I have a old rear blade and considering the fabrication of a dozer blade on a skidsteer. I have 2, daul action cylinders. Can I put one cylinder on each side to angle the blade? This will help balance the forces on the blade. One will push the same time the other pulls. The flow rates would be slightly different to each cylinder because of the push/pull. If I connect the cylinders by a "T" fitting in the hydraulic line, it should allow them to have different flow rates but same pressure. Is my reasoning correct?
   / 2 dual acting cylinders on a blade? #2
If the cylinders are identical, just reverse one of the cylinders. This will provide the same pressure and volume to each cylinder. Although one cylinder should do the job.
The dozer blade on my Power-Trac has one cylinder.
   / 2 dual acting cylinders on a blade? #3
Your reasoning is correct. That is how my 6 way blade is plumbed for angling on my Case dozer. Just use some tees and you will be fine.
I am considering using 2 cylinders rather than single larger one. I already have 2 smaller ones. I also thought 2 smaller ones may distribute the force better than just one large cylinder.
2025 Swict 60in Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2015 ISUZU NPR 16FT BOX TRUCK (A52141)
2015 ISUZU NPR...
CAT 963C (A47384)
CAT 963C (A47384)
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51243)
UNUSED FUTURE BOX...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
