radman1
Elite Member
- Joined
- Jul 8, 2006
- Messages
- 3,016
- Location
- midwest
- Tractor
- JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
I have a old rear blade and considering the fabrication of a dozer blade on a skidsteer. I have 2, daul action cylinders. Can I put one cylinder on each side to angle the blade? This will help balance the forces on the blade. One will push the same time the other pulls. The flow rates would be slightly different to each cylinder because of the push/pull. If I connect the cylinders by a "T" fitting in the hydraulic line, it should allow them to have different flow rates but same pressure. Is my reasoning correct?
