#2 Diesel VS #2 Heating Fuel
   / #2 Diesel VS #2 Heating Fuel #1
TTTTTT
Bancroft , Ontario
Dong Feng 354 (Oct 2008)
I am sure this question has come up a few times but could'nt see any recent thread. I am switching to Nat. gas for my home from oil and have about 600 l. of freash #2 home heating fuel worth about $600 these days. Doing some interent research and other forums, the concensus was that they are identical except for the dye thats added for tax reasons, and often they come from the same tanker and the dye is added on site. Thats what i have read..............so whats the feeling out there. i would be using it in a newer direct injection diesel engine for my tractor.
Should raise some interesting comment for and against.
Thx Dave
   / #2 Diesel VS #2 Heating Fuel #2
You are in Canada, so I would call your supplier and ask them what went into your tank. In the US it is pretty much guaranteed to be ULSD.
Aaron Z
   / #2 Diesel VS #2 Heating Fuel #3
In Northern Ontario here..........I have been using the red dyed " heating oil" cheaper stuff for two years now in my Kubota .I get it from the small town gas station in five gallon containers like many of the other farmers in my area do.
Sulpher content is still same "low" that is required.
   / #2 Diesel VS #2 Heating Fuel #4
Chances are it's ULSD.
Ask whoever you bought it from last, for an MSDS to make sure it's not cut with Solvents..
Thanks for the replies. Comes from a reputable supplier so i'm not worried about the quality. Plan to store it treated with conditioner in a 1300 l. fuel tank with proper filters etc.. Sounds like it should be a go. I hate to give away the fuel if I can use it.
Dave
   / #2 Diesel VS #2 Heating Fuel #6
You will want to treat it with an additive that will keep it from gelling in the winter. Maybe it's different up there but around here #2 heating oil is stored inside the home (usually in the basement). If it can't then the furnace is converted to burn kerosene. It would be a good idea to get an anti gel additive that is also a lubricant.
   / #2 Diesel VS #2 Heating Fuel #7
Dave
In Ohio my distributor has always said the diesel supreme I have delivered is the same as home heating oil. I asked about additives for tractor use, which is what I use it for, and he has always said they take care of additives and me adding more is just a waste of money.
Canada may be different but I doubt if too many folks up there would stand for home heating oil that clogged their furnaces in cold weather.
How often have you had fuel oil left over in your tank and used it the next cold season to heat your home? Any problems?
   / #2 Diesel VS #2 Heating Fuel #8
Around here, they are the same except for the dye. This comes from a friend who hauls the stuff for a living. As has been stated..... might be a good idea to add some Power Service or equivalent, to treat it for winter temps.
   / #2 Diesel VS #2 Heating Fuel #9
I would definitely contact your supplier and ask?
I thought home heating fuel oil was #1, I could be wrong.
I would mix it with #2 fuel. I costs nothing to ask.
   / #2 Diesel VS #2 Heating Fuel #10
#1 is kerosene. (which is also jet fuel.)
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
2004 INTERNATIONAL 4300 BOX TRUCK (A54607)
2004 INTERNATIONAL...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55301)
2023 NEW HOLLAND...
