2 Cycle oil mixtures?
   / 2 Cycle oil mixtures? #1
MrJimi
Elite Member, Rest in Peace
NorthEast, Florida
Case 1845 C Skid steer
If you buy the single use small container it says 3.2 OZ. per gallon?
If you buy the larger size/16 OZ. it says 2.6 OZ. per gallon.
There has to be a difference here and they both say 16 OZ. per 6 gallons?
How does that figure out
:eek:
   / 2 Cycle oil mixtures? #2
What it means is is that it just ain't all that critical and if you can measure .2 and.6 OZ you is better than me.
   / 2 Cycle oil mixtures? #3
It means some math doofus wrote the labels:cool:
   / 2 Cycle oil mixtures? #4
The mix depends on the requirements of your engines. I just mix 40/1 for all mine. That's 170 cc in 1.5 gallons. I keep an old 2 cycle oil container that has the cc graduations on one side of it.
Ralph
   / 2 Cycle oil mixtures? #5
3.2 oz = 40 to 1
2.6 oz = 50 to 1
Maybe they left that off the label?
SimS
   / 2 Cycle oil mixtures? #6
And 16oz per 6 gallons is 48:1:rolleyes:
   / 2 Cycle oil mixtures? #7
Sounds like you're messing with chainsaws, Jimi.
From what I heard at the saw shop, most of the new stuff is designed to run at 50:1 (2.6 oz./gal.) but will run almost as well and probably last longer with 40:1 (3.2 oz./gal.). The guys who hammer their saws hard all day long usually favor a 40:1 mixture even though it smokes a little more.
If you're talking outboards, better stick to 50:1 if designed for it. My favorite 9.8HP trolling motor became much harder to live with on 40:1. I should've known better; at trolling speeds, 80:1 would probably provide enough lubrication.
Bob
   / 2 Cycle oil mixtures? #8
A lot of oil injected 2 strokes, i.e. snowmobiles & outboards with variable oil pumps, go as low as 100:1 when idling. When using mixed gas one has to mix for worst case -full throttle. My weed whacker won't run on 50:1 saw gas but will run of 40:1 ??? The small bottles typically are branded by equipment name - labeled & quantified for their products needs. Oil branded quart bottles usually have a mixing chart for various ratios while equipment branded quarts will have a single mix ratio. There are many that believe that only Mercury oil can be used in their Mercury, Husqvarna oil in their Husky & and Arctic Cat oil in their AC, etc. I use Castrol for everything but mix according to application. It works for me. MikeD74T
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2015 Chrysler Town and Country Van (A50324)
2015 Chrysler Town...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52748)
2022 Quick Attach...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
1999 24DTA pintle hitch trailer (A52748)
1999 24DTA pintle...
