2 bottom plow problems
   / 2 bottom plow problems #11
Jeff, sounds like he's so far out of adjustment that it won't "sink". That's why I suggested blocks. Nothing at all dangerous about driving the tractor up on blocks.
   / 2 bottom plow problems #12
So here is my setup ford 3000 Diesel, ford two bottom plow, I have the leveling arm pulled all the way up but the plow is still running High on the left side so only one of the plows are in the ground. My question is the lift pins on the plow look like the can be rotate to change the angle of the plow so when it is in the row the left side of the plow will dig in as well. any suggestions?
Thanks in advance for the help.
The plow pins can rotate for alignment.
[video]https://images.app.goo.gl/jr7t81wiGnz1pdMGA[/video]
   / 2 bottom plow problems #14
Ovrszd,
My stabilizers have play but not shown. Thanks for pointing that out to all.
idaho2
   / 2 bottom plow problems #15
Ovrszd,
idaho2
Yep. These type threads get read by a lot of people trying to learn.
For such a simple device a moldboard plow requires fine tuning. Properly adjusted, a plowed field will leave no indication of the individual passes thru the field.
   / 2 bottom plow problems #16
Aint that the truth. You always start where it cant be seen and get it set.
You want everyone to marvel at how good it looks when they drive by.
   / 2 bottom plow problems #17
My Dad was very serious about that. I've saw him stop at the end and change the toplink a turn. Using Ford 8N with 2-14s. Then later 861 with 3-14s. :)
   / 2 bottom plow problems #18
This was my 2305 and a Brinly plow.
Thank you to everyone for the suggestions as a new farmer, it is a real learning curve. turns out the lift pin setup had slid, I am now able to get the left side to drop down and plow up the ground .. Thanks everyone
   / 2 bottom plow problems #20
No pictures and it didn't happen. :)
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
16ft T/A Flatbed Trailer (A56858)
16ft T/A Flatbed...
NEW Fork Extensions (A59000)
NEW Fork...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
