2" ball rated capacity question.
/ 2" ball rated capacity question. #1
Boiler74
Indiana (Purdue country)
John Deere 4710
I just purchased a 7k lb. dump trailer to pull with my Suburban. When I took a look at the 2" ball I have, I saw it was only rated to 5k lbs. I asked the dealer I bought the trailer from about this, and he said I'd be ok. But it's still nagging me. I've looked around, and can't easily find a 2" ball rated over 5k. I can't think that Load Trail would put a 2" ball on this 7k lb. trailer if they didn't think it would work. I just want to make sure I'm safe and legal. So am I ok?
Thanks,
Josh
/ 2" ball rated capacity question. #2
Thanks,
Josh
This site says they have 2" balls rated up to 8K.The Hitch Corner sells Draw-Tite trailer hitch accessories
It might we wise to take a look at the rest of the setup I know I was looking for a 7K ball when I got my car hauler but ended up with a 5K ball because the 2" stinger and hitch were only rated for 5K without weight distribution.
If you want to have a 7K (or higher) hitch you might end up replacing the stinger and possibly the reciver hitch as well.
/ 2" ball rated capacity question. #3
I'd look for a heavier rated ball, they have 2" balls rated to 8500 lbs.
Trailer Hitch Balls
For less than $10, is it worth the risk?
/ 2" ball rated capacity question. #4
I believe that when rating the balls they rate them for gross tounge weight.
/ 2" ball rated capacity question. #5
Thanks,
Josh
This is one of those situations in which you are "probably" safe; odds are in your favor. But it's a situation where I don't like just good odds; I want to be sure! And another ball isn't that expensive. In fact, etrailer has them in 10k pound ratings and that's what I'd buy.
/ 2" ball rated capacity question. #6
I think I got mine from etrailerhitch.com. or truckperformance.com
I have a putnam ajustable ball mount rated for 10k. The hole takes a 1 1/4" shank. My trailer ball is a 1 1/4" shank rated for 8k. My new trailer is a 12k and takes a 2 5/16 ball. I bought one rated 10k and a solid ball mount rated the same. You can find what your looking for, but you may need to upgrade the ball mount also. JC
/ 2" ball rated capacity question. #7
Take the 2" hitch off and put a pintle ring on it.
/ 2" ball rated capacity question. #8
Buy the heavier rated ball, be safe for yourself and everybody else on the road.
steve
/ 2" ball rated capacity question. #9
Buy a new ball and make sure your hitch is rated for that much weight. You might only have a 5K hitch.
Thanks all. I will get the heavier ball and a weight distributing hitch for those heavier loads. Want to stay safe.
Josh
/ 2" ball rated capacity question. #11
Your hitch coupler is probably a 7k Bulldog hitch and you can get a 8K ball for 8.95 and a 8.5k for 14.95 at etrailerpart.com. They are more than likely a Putnam brand. Make sure your reciever is rated for 7k min also, I have a 10k that is cushion mounted and they make them up to 15k in the solid shanks.
/ 2" ball rated capacity question. #12
As you may have noticed is that the higher rated 2" ball has a larger diameter shank. You'll have to buy another ball hitch for the larger diameter. Why not just change the trailer coupler and ball to a 2-5/16"? This way you want have to buy a distibution hitch, plus peace of mind.
/ 2" ball rated capacity question. #13
Tongue weight is measured as DOWNWARD force on the hitch. Most trucks are rated for well under 1000#. I think you might be confused.
Bear in mind that some vehicles specifically advise against weight distributing hitches. They are great additions, but make sure the vehicle will take a distribution hitch before installing one.
2025 32in. Tilting Bucket Mini Excavator Attachment (A61572)
2025 32in. Tilting...
KMC 3386 (A64119)
KMC 3386 (A64119)
(6) 8" X 8" TREATED TIMBERS (A63291)
(6) 8" X 8"...
2016 VOLVO EC250EL EXCAVATOR (A64279)
2016 VOLVO EC250EL...
2018 BOBCAT E50 EXCAVATOR (A64279)
2018 BOBCAT E50...
Caterpillar 3208 Truck Engine Service, Parts and Operation Manuals (A63117)
Caterpillar 3208...
