2"ball for my back hitch...
   / 2"ball for my back hitch... #1
BlackOps
Platinum Member
northern middle tn
Mahindra Max 25
is this the most common size ball for a back hitch i want to put on my tractor? is this the normal most used size? i forgot what my last truck had on it.
   / 2"ball for my back hitch... #2
2” is the most common. 1 7/8” is for light stuff that get pulled behind little cars. 2 5/16” is for heavy trailers like car haulers and big cargo trailers.
Beyond that it’s into the commercial stuff.
Edit to correct 2 5/16” size.
   / 2"ball for my back hitch... #3
It depends on what hitch is on your trailers. All of my trailers are 2 5/16". If you have different size hitches on your trailers mount a 2" receiver on back of your tractor and get a tri ball hitch to plug into it.
   / 2"ball for my back hitch... #4
I standardized a succession of vehicles on 2 inch ball, to match occasional U-Haul rentals.
Later this was correct for three different small travel trailers - two of them pop-up tent trailers.
And got a 2" hitch for it, when I bought a tiny Harbor Freight trailer.
I think 1 7/8" is becoming obsolete, I would't use it for anything.
2 inch is fine for anything you would pull with the Mahindra as a farm implement. If you need to move around a big heavy road trailer, would be the only reason to get the multiple ball mount including a larger ball.
   / 2"ball for my back hitch... #5
As others said,just purchase heavy duty 2" tho.
Thanks - i thought it was the 2".
   / 2"ball for my back hitch... #8
Agreed, for a tractor that is probably going to be used as a "tug" for all sorts of stuff, a tri-ball is the way to go.
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
John Deere 250 Skidloader (RUNS) (A50774)
John Deere 250...
KUBOTA ZD1211 (A53084)
2016 Ford Fusion S Sedan (A50324)
2016 Ford Fusion S...
(7) John Deere Weights (A50121)
(7) John Deere...
2013 Cadillac SRX SUV (A50324)
2013 Cadillac SRX...
