2 acres too small for a tractor?
   / 2 acres too small for a tractor? #61
GREAT LOOKING TRACTORS !!
I had chance to look at the grnspot110 tractors in more detail. I really like the Lo Boy and the LA. Very nice work restoring the old girls grnspot110!
   / 2 acres too small for a tractor? #62
2 acres is plenty for a tractor. I managed with a riding mower and garden tractor. With our property now, needed a FEL, and bought a SCUT.
   / 2 acres too small for a tractor? #63
Should the question be "Do I need more than one tractor for two acres?"
   / 2 acres too small for a tractor? #64
   / 2 acres too small for a tractor? #66
Rent a tracked skid steer to clean up your property and maybe even level some of it. Then you will have a nice safe place to play on your tractor.
   / 2 acres too small for a tractor? #67
It might be overkill but i have a 40 hp tractor with a 6' finish mower mower for my place. A wicked root grapple for moving wood and removing brush and trees. Saves a ton of time and labor, these are all projects I could do without the tractor but WHY.
   / 2 acres too small for a tractor? #68
I keep wondering if I over bought. I wish I didn't have theis blasted hill so I had more level land to work. I think that makes a world of difference. I just don't have that much to be able to till or plow and plant. I can do a bit more than I've started so far, but not a lot.
It has made some of the work a lot easier and I've been able to do things I wouldn't have without it. But none of those really NEEDED to be done.
I can make use of it, but I'm pretty sure I could have done with a lesser machine like a JD X5XX or X7XX series or equivalent. But then I realize I would have been near $10K or a bit less and not able to do some of the things I can with this.
I don't need a grapple or anything like it. I can chainsaw trees where they fall and load the bucket or a trailer. I would like a stump grinder, but I was a bit (OK a LOT) shocked at the prices.
   / 2 acres too small for a tractor? #69
That model Kubota M5660suhd, seems like overkill for a two acre plot. Its a 56 HP tractor according to Kubota. I've used a Ford 1220 FWD, with Box Scrapper, Brush Hog, and Front End Loader to do almost everything on my 4 acres for over 20 years. Its only 14 HP PTO rated. With it I've: Graded the 1.5 mile gravel access road - 6 degree slope, pulled many a car out of the ditches, dug up and moved well over a thousand tons of large rocks, removed snow, dragged out logs, graded large areas of the property, backfilled, moved dirt and mulch, run a chipper, Brush Hogged through old growth blackberries and saplings up to 2 inches. Graded for paver pathways. Moved boats around. Collected large rounds of firewood from a neighbors tree farm, cleared the access road of fallen trees after windstorms. I can't imagine not having a tractor. And mine is half the tractor you are looking at buying. Bought mine 10 years used, with attachments for $6500.
   / 2 acres too small for a tractor? #70
That model Kubota M5660suhd, seems like overkill for a two acre plot. Its a 56 HP tractor according to Kubota. I've used a Ford 1220 FWD, with Box Scrapper, Brush Hog, and Front End Loader to do almost everything on my 4 acres for over 20 years.........................
We have your Ford's smaller brother, a 1210 since back in 1991 or so. It's incredible what that little guy can do. Bought it as a used bare tractor and have been using a 5' RFM, scraper blade, 3-point scoop, York rake and other stuff ever since.
Of course, when the opportunity to get larger toys, who can resist?
UNUSED FUTURE MINI EXCAVATOR HEDGE CUTTER (A51244)
UNUSED FUTURE MINI...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
