2 acres too small for a tractor?
   / 2 acres too small for a tractor? #21
We bought a hillside in the northwest. I'm worried about driving a tractor due to the slopes, although my JD lawn mower does fine.
A subcompact tractor with rear wheel spacers and with the Loader removed will be more stable than your lawn mower.
If you order the optional SSQA (Skid Steer Quick Attach) Loader to Bucket connection, you can drop the 200 pound bucket in one minute.
Removing the entire Loader takes perhaps seven minutes on the current generation of subcompact tractors.
VIDEO: Kubota LA34 \ LA344 Swift-Tach loader for BX-8 series tractors - YouTube
It is carrying Loader loads raised higher than 12" on slopes that makes tractors particularly unstable.
You may wish to consider rear wheel weights too. Wheel weights provide more stability than liquid filled subcompact tractor rear tires, which have very low internal volume.
R1/ag tires provide somewhat better traction on slopes, both up/down and across, however almost all tractors sold with Loaders are sold with R4/industrial tires, as six-ply R4s do not squat down under Loader loads like four-ply R1 tires. R4 tires usually do not mark lawns. Pretty close choice between R1/R4 tires on mostly sloped land.
The main drawback to subcompact tractors is low ground clearance of 7" to 9" depending on brand and model.
Compact tractors (CUTS) have 12" to 14" ground clearance.
VIDEO: Kubota BX Series VS. B Series - YouTube
WHAT IS THE ALTITUDE OF YOUR LAND? Non-turbo tractors loose 3% of horsepower for every 1,000' increase in altitude.
   / 2 acres too small for a tractor? #23
Unless you go in deep mud, ground clearance on a lawn, driveway, even on trails in the woods is over rated. If you put a mid mount mower on it, it's even less important. Don't let that be a deciding factor at all, unless you plan on going in the mud often.
   / 2 acres too small for a tractor? #24
We just bought a hillside in the northwest. Neglected; huge piles of yard waste, blackberries, settling soil, fallen trees, etc. I'm worried about driving a tractor due to the slopes although my JD lawn mowr does just fine. So is having a tractor on 2 acres overkill?
I think you will be able to put a subcompact tractor to good use. I know several people that have lots that size who have tractors. If you are trying to beat the jungle back (and it sounds like you are) then a riding lawnmower won't get it done.
   / 2 acres too small for a tractor? #26
Aaaaaaand finally TBN'rs love to spend OPM...:laughing:
Now ask us what model you should buy, should be good for another post or two....
   / 2 acres too small for a tractor? #27
Well I bought my 23HP B7610 when I only had a 1/4 acre lot to maintain in Northern Virginia.
578818d1542151177-2-acres-too-small-tractor-log2-jpg
But then another house on a half acre lot I've got in Northern Virginia needed a lot of brush removal. So twice the lot, twice the HP. I bought my 50HP M4700 and used that to clean up the property,
578819d1542151216-2-acres-too-small-tractor-8x6-g4-forks-low-jpg
Worked well :)
/edit I've also got about 400 acres in Mississippi where the M4700 resides now
   / 2 acres too small for a tractor? #28
I agree. I don't have a belly mower and I have driven over small logs and navigated some real rough terrain with my BX. I did throw on under armor which I think is a must of you go off road/grass to avoid sticks messing up things underneath... at least with a BX.
   / 2 acres too small for a tractor? #29
I hate belly mowers. So I use a 72” cut diesel zero turn to cut my 1 acre yard.
   / 2 acres too small for a tractor? #30
On TBN that is a loaded question...
If you live in a "little" house on a postage stamp size lot but it has a driveway and it snows there at least 6" once a year...(according to some here) you will need a tractor and either a blower or a blade...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
6-row Tine Cultivator (A52128)
6-row Tine...
2018 ford explorer (A50324)
2018 ford explorer...
2018 CATERPILLAR 239D SKID STEER (A51242)
2018 CATERPILLAR...
2017 Claas Jaguar 860 Forage Harvester (A52128)
2017 Claas Jaguar...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
