2-4D
   / 2-4D #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I am wanting to over seed some pastures that I planted this spring, big mistake. So I want to get rid of the weeds and over seed. Can I just spray with some 2-4D wait for the weeds to die then over seed and run a fence panel over it to shake the seed to the ground?
   / 2-4D #2
That stuff works good on broadleaf weeds, you could use a "no-till" grain drill to seed it.
   / 2-4D #3
Eric, are there any vineyards in your area? I am not sure exactly where you are located but if you have any vineyards within 2 miles (on a very calm day) of you then don't use 2-4D. 2-4D is very harmful to grape vines and using it near them will make you liable for damages.
   / 2-4D
The closest vinyard is about a 45min drive. The farmer we bought the land from looks like he has wheat in the field behind us. If I could find where to rent a grain drill of any kind I would try that. Until then I am left with a broadcast spreader.
   / 2-4D #5
Are some varieties more prone to damage than others? I have been using 2,4-d for a while - years really. It's the prime ingredient in weed-b-gone and most other lawn sprays. I have sprayed right up to my grapes - concord and niagra - with no damage noted.
jb
   / 2-4D #6
I do not know about your situation but 2-4D will damage concords and most grape vines. It is illegal to use it within 2 miles of any vineyard in this county.
   / 2-4D #7
I was looking up the label for 2-4D and found out they actually give directions for spraying in grapes:rolleyes:
Of course they want you to use a hooded boom sprayer and apply only to the weeds after bloom but before the grape shoots reach the ground. The label does say to not apply 2-4d to foliage, shoots or stems. Why they would even start to recommend using it in vineyards is beyond me. One of the plants 2-4D controls is vines.
But never use a 2-4D ester in or near a vineyard. The fumes alone will damage the vineyard.
There is even a website dedicated to just 2-4D www.24d.org
   / 2-4D #8
Yes
I think it's 14 or 21 days that you need to wait after spraying 2-4D before planting again. it's in the instructions.
A chain harrow works better (kinda covers it up) but a fence panel will work too.
   / 2-4D #9
2-4D will also take out a tree if you get it on the leaves. It doesn't bother the bark, as long as there are no cuts in the bark. I just use it on fence rows.
hugs, Brandi
   / 2-4D #10
I know, it isn't good for too many broadleafs which is why it isn't legal to use near vineyards here. It doesn't take much at all to damage the vine.
2018 John Deere 460E Articulated Dump Truck (A53473)
2018 John Deere...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
