2 100 amp load centers or 1 200 amp load center?
   / 2 100 amp load centers or 1 200 amp load center? #1
wedge40
Wanting to start getting electrical supplies for the barn.
Not sure what exactly sure what equipment I'll have but here is a list of the larger items I can think of.
220v 2 stage compressor
220v table saw.
220v electric dryer.
220v tankless water heater.
220v 50 gal water heater - radient floor heat supply.
120v outlets every 8ft min.
Should I get 2 100 amp panels or one 200 amp panels.
Wedge
   / 2 100 amp load centers or 1 200 amp load center? #2
I would put in one 200 amp panel ...it is a better install with only one feed and plenty of room to expand.
   / 2 100 amp load centers or 1 200 amp load center? #3
A 200A 40 space box isnt twice the price of (2) 100A 20 spacers. It is only about 20% more.
And the feeder wire ALSO isnt double the cost. 200A wire is only about 20% more as well.
So it will actually be cheaper and just as good to go with 1 200A panel and feeder. UNLESS this is a huge barn and you were planning on one panel at each end to limit the length of wire running to your 220V higher amperage utilities. Not sure what the amperage is on some of them, but for indoors 50A, you need 6ga copper. And that stuff aint cheap. So keep that in mind as well when laying everything out. Keep the higher amperage stuff as close to the box as you can. Because to feed it is $$$$$
   / 2 100 amp load centers or 1 200 amp load center? #5
Have you calculated planned load? Without doing so its all a guess. Plus most areas require load calculations before issuing an electrical permits.
That being said, a 200 amp panel installation will be cheaper than two 100's. You'd still need to build a 200 amp service, and either provide two 100 amp sub-mains, add multi connection lugs to the meter, or a gutter to split to two locations, depending on local codes. Unless the meter housing is rated for multi conductor terminations per lug, it's illegal to tap more than one connector per termination.
Its not so much the cost, but rather making sure I dont have an unbalanced load issue.
Wedge
   / 2 100 amp load centers or 1 200 amp load center? #8
I was thinking hard about it is there a generator in the future?
That might be a reason for 2 panels.
one for the generator loads, one for who cares I don't need it now.
tom
   / 2 100 amp load centers or 1 200 amp load center? #9
I see no reason to run 2x100A panels. 220V loads are automatically balanced, as Kenny noted since they draw from both legs. Unless you do something really goofy with the 110V outlets, they will naturally balance out also, as every other breaker alternates from one leg to the other. In other words, you put in a 100v breaker and it connects to leg "A". Put in another one directly below it and it will be connected to leg "B"
Plus I recall a code restriction that there can only be one main panel for any building for safety reasons. In which case if you wanted 2 panels on opposite ends, you would be better off putting in a main 200A panel and running a second panel as a sub panel off of that. But I don't think you can legally put int 2 independent 100A panels.
   / 2 100 amp load centers or 1 200 amp load center? #10
A single 200 amp, for sure. Can't have 2 feeds to one building 'here' legally, not sure what you try to gain with a pair of 100 boxes - complexity & problems & cost if legal at all?
--->Paul
Powder River Squeeze Chute (A55218)
Powder River...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
